Question cropped bar
14 years 11 months ago #94025 by ronny
cropped bar was created by ronny
Excuse me, why is the bar below my post cropped as seen in the image?
How to fix this?
Thank you for the help
14 years 11 months ago #94026 by sozzled
Replied by sozzled on topic Re: cropped bar
This has something to do with the Joomla site template that you're using. If you post you K 1.6 configuration report we may be able to offer you some better advice.
14 years 11 months ago #94027 by ronny
Replied by ronny on topic Re: cropped bar
Here is my configuration report:
htaccess: Exists | PHP environment: Max execution time: 6000 seconds | Max execution memory: 256M | Max file upload: 250M
Joomla default template details : hot_relief | author: HotJoomlaTemplates.com | version: 1.0 | creationdate: March 2011
Kunena default template details : Euro-Brown | author: Mizunga | version: 1.6.1 | creationdate: 2010-12-20
14 years 11 months ago #94029 by sozzled
I was mistaken. The problem is not with your site template. You are not using a Kunena template compatible with K 1.6.3. Please use the Blue Eagle template or contact the person who designed/developed the Kunena template that you are using. That should fix your problem.
14 years 11 months ago - 14 years 11 months ago #94032 by ronny
I have tried using blue eagle but that doesn't fix the problem. Any better advices?
Thank you
Last edit: 14 years 11 months ago by ronny.
14 years 11 months ago #94033 by sozzled
You are not using the standard, unmodified Blue Eagle template. Your site looks no different now than when I last looked at it. Please use the Blue Eagle template and let us know when you have done that. Then we will look at your site again. Thank you.
Time to create page: 0.268 seconds
