Question Why is my post text so ugly?
15 years 7 months ago - 15 years 7 months ago #92252 by dank
It should be noted I only turned legacy mode on before I knew what it was to see if it was the problem. Since reading about it here, it is now off.
[img]http://http://i177.photobucket.com/albums/w212/iamshroom/uglytext.png[/img]
The background is actually dark grey not black but I couldn't get it to show right in any image editors.. Here's a link to the post if it helps more- ugly post
As you can see most of the text is misaligned, anything blue is very blurry etc.. etc.. I have no idea why it does this but it's very ugly and annoying... Please help...
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : gored_ultra_lernvid.com | author: Juergen Koller | version: 1.4 | creationdate: 21.03.2010
Last edit: 15 years 7 months ago by dank.
15 years 7 months ago - 15 years 7 months ago #92314 by sozzled
G'day, dank, and welcome to Kunena.
dank wrote: As you can see most of the text is misaligned, anything blue is very blurry etc.. etc.. I have no idea why it does this but it's very ugly and annoying... Please help ...
People do not understand how Joomla works.
First of all, when a page is produced by Joomla, all the data is collected, the plugins that work on the data are run, the component is rendered and any CSS that applies to the component is then applied. Then the modules are run (and modified by plugins) and then the CSS of the modules is then applied. Then the site template CSS is applied last of all. So you see, the content generated by Kunena can be changed by other things that are run later.
Your "ugly text" is caused by your Joomla site template. That's something you can discuss with the people who designed and developed your Joomla site template. It all depends on what is more important to you: your site template or Kunena. Sometimes you can't have everything you want ... well, not without paying for it in some way, anyway. See Which came first? The template or the forum?
In actual truth, none of us can actually see the problems that you've described in very broad terms because only registered users can access your forum.
Last edit: 15 years 7 months ago by sozzled.
15 years 7 months ago #92354 by dank
I had originally thought it was the Joomla Template causing it as well, but it happens with the default templates too.. After messing around a bit I found it was my Kunena template causing it. So I'm going to just try to edit the colors of blueeagle template and see if that works out better..
Thanks for the help.
