Question How do I hide the "Views" column from my template
- KateKoch44
- Junior Member
15 years 1 month ago - 15 years 1 month ago #92030
by KateKoch44
How do I hide the "Views" column from my template was created by KateKoch44
Last edit: 15 years 1 month ago by sozzled. Reason: Changed subject to improve relevance for search purposes
15 years 1 month ago #92089
Replied by sozzled on topic Re: How do I hide the "Views" column from my template
Thank you for your interesting question. Although the specific mechanism that you may have used in K 1.5 will not work in K 1.6, the method is still similar. Perhaps if you would like to explain how you made the changes in K 1.5 we may be able to suggest a solution that will work for you in K 1.6.
It's my guess that you need to "doctor" the PHP source code for the template. As soon as you do that, you're on your own as far as continued support from the Kunena project team is concerned. Your choice; those are the consequences.
- KateKoch44
- Junior Member
15 years 1 month ago #92095
by KateKoch44
Replied by KateKoch44 on topic Re: How do I hide the "Views" column from my template
As mentioned in the other thread, I'm not familiar with PHP or CSS and I try to leave that to my tech guy. I was hoping to get a jump on it if you gave me specific info. I'm just glad it is possible. I'm cool with the consequences. I never had a problem before and I doubt I'll have a problem again. If I do, it will be my problem.
15 years 1 month ago - 15 years 1 month ago #92103
You can hide this column by adding the following three lines to your Joomla site template:
#Kunena td.kcol-ktopicviews {
display: none;
display: none;
- KateKoch44
- Junior Member
15 years 1 month ago #92104
by KateKoch44
THANK YOU!
- allmyhoney
15 years 3 weeks ago #93051
by allmyhoney
Replied by allmyhoney on topic Re: How do I hide the "Views" column from my template
Hi there, can you tell me where exactly this css code goes? I added to my t3 template with joomlart but no luck? does it go anywhere in the css files for kunena? :blush:
Time to create page: 0.223 seconds
