Question Possible to change the admin color from red to blue?
15 years 7 months ago #88557 by craig
In my forums the admin name is lit up red, while other users are blue. I would like to have the admin be the same blue color instead of red. Can someone tell me how I would do this?
15 years 7 months ago #88559 by sozzled
Simple.
Add the following three lines in your Joomla site template
#Kunena .kwho-admin, #Kunena a.kwho-admin {
color: #5388B4 !important;
The following user(s) said Thank You: craig
15 years 7 months ago #88664 by craig
Great. Love it when it's so easy!! :cheer:
15 years 7 months ago - 15 years 7 months ago #88897 by gpsyv
sozzled wrote: Simple.
Which file in the Template?
Best Regard,
Carlos-Venezuela
Last edit: 15 years 7 months ago by gpsyv.
15 years 7 months ago #88929 by sozzled
sozzled wrote: ... your Joomla site template
The answer may be different depending on how your Joomla site template was designed. Using Firebug for Fireboard will tell you exactly which file (or files) are involved. If you cannot resolve this out, I suggest you contact the developer of your Joomla site template to find out the relevant information. :)
15 years 7 months ago #88934 by gpsyv
sozzled,OK, I resolved by modifying in the Template "template_css.css" file.
Thanks, Best Regards
Carlos-Venezuela
