Question Auto resize limits for signature images in signature area
15 years 7 months ago #84644 by SkeeterUK
Hi there.
How do you set the width of signature box images in Kunena 1.6.3 latest? The parser has changed. The sigs now break forum areas so i wana smallen them slightly with kunena and not have to manually do it to each one.
Pleas help asap.
www.therisenphoenixfleet.com/index.php/f...etings-from-ufp.html
As you can see some of the sig pictures are disapearing off the right side a bit so if i can auto shrink (max width) to about 725 or 700px wide (if i have to). How would i do it which setting in the Kunena_parser file or can it be easier to change now in latest version (last time i tweaked to work was in kunena 1.5 somit or other.
15 years 7 months ago #84663 by SkeeterUK
I managed to fix it. ;)
It wasnt the parser file like in old kunena it was a css this time so not as bad (hardcoded) as it used to be so thats a relief.
File that did the trick was Kunena.default-min.css kmsgsignature set to 700px width max and 200px height max.
15 years 7 months ago #84673 by sozzled
A couple of comments.
People should not directly edit the file kunena.default-min.css. Yes, that's where the CSS definitions are contained but this is a minified CSS file (and this advice applies whether you are editing the CSS for the Blue Eagle (default) template or someone else's template); you should never edit files in default template folder - they are replaces every time you upgrade Kunena and any changes you make in the default template folder will be lost when you upgrade. Changes made in a your own or a custom template folder are not affected by Kunena upgrades. Please see Minified CSS in the Wiki.
Time to create page: 0.235 seconds
