Merged [Resolved] [Merged topic] Blurred, blurry, fuzzy, text in Kunena menu (text-shadow)
15 years 4 months ago #82388 by smoothdude11
Today I decided to install Kunena as the forum for Jomsocial. However the text on the main menu has like doubled up and is making it blurry. Here
Everything else is set to default. Anyone else have this problem or know of a solution to fix this? I did do a search before I posted this, but I could not find anything similar.
15 years 4 months ago #82393 by yuzef
Replied by yuzef on topic Re: Kunena Main Menu Problem
i visited your site, i "think" that caused by your rockettheme juxta template. try to use default Joomla! 1,5 (rhuk milkway) and see there must be fine about your blurry menu.
Love Simplicty
read...... and learn........
My Joomla Test Site
15 years 3 months ago - 15 years 3 months ago #87629 by tgotch
Replied by tgotch on topic Tabs Shadow
I noticed the font in my tabs has a shadow/is a bit blurry.
Anyone know how to fix this? (Default template with 1.6.3)
screen shot:
Last edit: 15 years 3 months ago by tgotch.
15 years 3 months ago - 14 years 4 weeks ago #87654 by sozzled
Replied by sozzled on topic Re: Tabs Shadow
We've seen the issues before. They're Joomla site template issues.
See (for example): I hope this helps
Last edit: 14 years 4 weeks ago by sozzled.
14 years 2 months ago #121866 by PokerJoe
I am using
Joomla 2.5.4
Rocket Theme - Kinetic v1.6.1
JomSocial 2.4.2
Kunena 1.7.2 | 2012-01-31 | 5215 [ Omega ]
The Kunena menu is fuzzy. Only the Menu tabs everything else works fine
I have posted this same issue at the Kunena forum as well. I would like the RT teams opinion of how to fix this.
The URL for the issue is jgpproductions.us/forum
The only customization made has been to the Logo and a few other images to create a uniform look for this site. No changes have been made to any php or css files.
If someone would like admin access to help with this let me know i will make an account and get you the permissions.
14 years 2 months ago #121868 by snilloconator
Hello PokerJoe,
Find your kinetic template.css yoursite\templates\rt_kinetic\css\template.css
Add the following code and it should resolve the text shadow.
#Kunena #ktab a span { text-shadow: none; }
