Question Remove "Rules" & "Help" Menu Tabs and "Mark all Topic Read" button not displaying correctly
15 years 10 months ago #82062 by crystalm28
Hi :)
I have two small items:
1. The "Mark all Topics Read" button does not expand past "Mark all T". So the "opics Read" is cut off. This is probably because I am using a smaller pixel width area? How do I correct this?
2. How do I remove the Rules & Help Tabs all together?
I love the forum and wanT to thank the Developers!!! GREAT JOB!!!
15 years 10 months ago #82122 by sozzled
You have two different subjects merged into one topic.
One of your problems is a template issue. The other problem is a commonly-asked "how do I do this?" issue. Which one of these problems would you like help with under this topic? Please search for, or create a separate topic, for the other topic. Thank you. :)
Hint, the "how do I remove the help and rules tabs" question has been asked dozens of times! ;)
15 years 10 months ago #82226 by crystalm28
Thank you :). Sorry about that!! I will search for the tab question. So can you help me with .....
Thank you..Thank you...Thank you :).!!
15 years 10 months ago #82261 by sozzled
Yes, we can help you with the issue that you are having - best described as "My Joomla site template messes up the'Mark all Topic Read' button".
There are two ways we can help you:
(1) Without us looking at your website, you can use Firebug for Firefox to see what is causing the wrapping of the button caption.
(2) If you want us to look at your website (and suggest ways to correct the issues that were caused by the Joomla template that you have chosen) then you are going to have to show us your website. Do you think that will be a problem?
15 years 10 months ago #83015 by crystalm28
Thank you :). I will try Firebug and let you know what happens. Attached is a print screen of the issues.
Thanks again :)!!!!:cheer:
15 years 9 months ago #84596 by crystalm28
Please see attached. Mark all Topics Read button is not showing correctly.
Thank you :)
Crystal
Time to create page: 0.145 seconds
