Question Remove "Rules" & "Help" Menu Tabs and "Mark all Topic Read" button not displaying correctly
- crystalm28
- Junior Member
I have two small items:
1. The "Mark all Topics Read" button does not expand past "Mark all T". So the "opics Read" is cut off. This is probably because I am using a smaller pixel width area? How do I correct this?
2. How do I remove the Rules & Help Tabs all together?
I love the forum and wanT to thank the Developers!!! GREAT JOB!!!
One of your problems is a template issue. The other problem is a commonly-asked "how do I do this?" issue. Which one of these problems would you like help with under this topic? Please search for, or create a separate topic, for the other topic. Thank you.
Hint, the "how do I remove the help and rules tabs" question has been asked dozens of times!
- crystalm28
- Junior Member
Thank you
Thank you..Thank you...Thank you
There are two ways we can help you:
(1) Without us looking at your website, you can use Firebug for Firefox to see what is causing the wrapping of the button caption.
(2) If you want us to look at your website (and suggest ways to correct the issues that were caused by the Joomla template that you have chosen) then you are going to have to show us your website. Do you think that will be a problem?
- crystalm28
- Junior Member
Thanks again
- crystalm28
- Junior Member
Thank you
Crystal
