Question Border color problem in IE 8
15 years 10 months ago - 15 years 10 months ago #81475 by celdric
Hi. I just installed Kunena on my new site. It's a dark rocket-theme template. I'm using the blend option and so far in Firefox it looks great. But not in IE 8. Internet Explorer displays the dark borders as white borders. Screenshot attached. Looks not good. What can I do to change that? I'm not able to edit the Kunena css. Are these big text blocks intended? Maybe there is a special editor required to edit these block?
Last edit: 15 years 10 months ago by celdric.
15 years 10 months ago #81678 by severdia
Can you post a URL? It's preferred to add CSS that overrides your Kunena template to the main template CSS file. That way you can easily upgrade and keep your customizations.
15 years 10 months ago #82043 by celdric
Hi, thanks for your response. The direct link to the forum is
wirdeutschen.com/main/index.php?option=c...tmenu=434&Itemid=432
and the site link is
I'm currently restyling the site. Please don't type in just wirdeutschen.com . Then you get linked to the old version.
15 years 10 months ago - 15 years 10 months ago #82196 by celdric
Attachment not found
I found another color problem. While in IE all box backgrounds are white witht the result that the text isn't readable in Firefox the backgrounds are dark and okay. I attached a screenshot of the new topic page.
I wonder if it's not possible to implement an easier way to make those simple color changes. In Kunena template admin are already some options. Perhaps there should be also the option to change the general background and borders of a forum and the general text color. In my opinion that would be already a big help especially if you are using dark joomla templates.
15 years 10 months ago #82407 by celdric
Never mind. I found a way to solve the problem by myself.
15 years 2 months ago #105697 by SargeSaunders
I have this same issue could you tell me what settings you changed to fix IE 8 or 9
