Question Rendering the Kunena menu links as tabs (SOLVED)
15 years 10 months ago - 15 years 9 months ago #81016 by Lili
I installed Kunena on a website and I am getting everything that I want with this component. The only problem that bugs me is that I want to have tabs instead of links for my Kunena Menu.
Here is the look
And as in this forum I want to have tabs
I checked all wiki and informations and did everything that it says. I keep having those links.
Here are the infos :
Joomla : Joomla! 1.5.22 Stable
PHP : 5.2.4-0.dotdeb.1
Kunena 1.6.2
Thanks for your help I luv Kunena and will use this component on all the forums that I will make B)
Last edit: 15 years 9 months ago by Lili.
15 years 10 months ago #81023 by sozzled
Lili: Getting the unformatted links to be formatted so that they appear as tabs is governed by the CSS used in your Joomla site template. But, sometimes, even if you have the CSS defined, some web browsers still won't show things properly.
So, the issue is probably a site design issue. We might be able to help but, in order to do that, we're going to need to see your website. Can you provide us with the URL of your site forum, please?
15 years 10 months ago - 15 years 10 months ago #81025 by Lili
Last edit: 15 years 10 months ago by Lili.
15 years 10 months ago #81037 by sozzled
Hmmm ... this is really tough. I'll be totally honest with you: I've had more problems resolving Artiseer templates than I've had with any other problems/issues/questions asked here at www.kunena.org .
I'm sure we'll get an answer on this topic, soon. I might have to think about it for a few hours (or days).
15 years 10 months ago #81198 by sozzled
I spent a couple of hours looking into this issue. I think that I have a solution. The solution involves using the Kunena Create Menu facility. I think that the problem is there because there has been a change made to the way that the software usually works. We may know more soon.
See PM.
15 years 10 months ago #81210 by sozzled
Issue resolved by "trashing" menu links and using Kunena Create Menu facility.
