Solved How do you override #Kunena a:active
15 years 8 months ago #80748
by sebnunes
How do you override #Kunena a:active was created by sebnunes
Hi all,
I changed the default css to match my customer needs, but despite I change the following lines, my changes are not applied.
When I check the source code of the page I see that the following lines of styles are injected in the HTML:
So how do you change the default color for links ?
#Kunena a:link,
#Kunena a:visited,
#Kunena a:active {color: #FFFFFF;}
<style type="text/css">
/* Kunena Custom CSS */ #Kunena div.kheader { background: #414141 }
#Kunena #ktop { border-color: #414141 }
#Kunena #ktop span.ktoggler { background: #414141 }
#Kunena #ktab a:hover,
#Kunena #ktab li.Kunena-item-active a { background-color: #414141 }
#Kunena #ktab ul.menu li.active a { background-color: #414141 }
#Kunena a:link,
#Kunena a:visited,
#Kunena a:active {color: #414141;}
#Kunena a:focus {outline: none;}
#Kunena a:hover {color: #FF0000;} [color=#bb0000]#Kunena a:link,
#Kunena a:visited,
#Kunena a:active {color: #5388B4;}[/color]
#Kunena a:focus {outline: none;} #Kunena div.kannouncement div.kheader { background: #414141 } #Kunena div#kannouncement .kanndesc { background: #222222 } #Kunena div.kfrontstats div.kheader { background: #414141 } #Kunena div.kwhoisonline div.kheader { background: #414141 } #Kunena .kicon-profile { background-image: url("http://www.ducati-sud-belgio.be/9.0/components/com_kunena/template/default/media/iconsets/profile/default/default.png"); }
#Kunena .kicon-button { background-image: url("http://www.ducati-sud-belgio.be/9.0/components/com_kunena/template/default/media/iconsets/buttons/blackbird/default.png"); }
#Kunena #kbbcode-toolbar li a,#Kunena #kattachments a { background-image:url("http://www.ducati-sud-belgio.be/9.0/components/com_kunena/template/default/media/iconsets/editor/default/default.png"); }
/* End of Kunena Custom CSS */
</style>
15 years 8 months ago #80793
Replied by sozzled on topic Re: How do you override #Kunena a:active
You can "override" the CSS rules by adding them to your Joomla site template. The Joomla site template (which is the last CSS to be loaded) overrides just about everything.
You can apply your own CSS rules, by modifying the Kunena template CSS, but this is a little tricky. To understand how the Kunena template CSS works, you should do a bit of background reading. Start with Minified CSS and work your way from there.
The question may not be a case of "how do I make the changes" but, instead, "where do I need to make the changes". I hope this helps.
The following user(s) said Thank You: sebnunes
15 years 8 months ago #80837
by sebnunes
Replied by sebnunes on topic Re: How do you override #Kunena a:active
OK, thanks for your answer.
Indeed, it's not how, but where. But I don't understand why kunena injects hardcoded values in the HTML while there is a dedicated css for kunena.
15 years 8 months ago #82007
by TauxFu
Replied by TauxFu on topic Re: How do you override #Kunena a:active
I've been trying to change my default link colours as well. I successfully changed the colours of everything else in the forum other than the type of links I've outlined in red. Hello tacky!
I found the hex & decimal codes for the colours i need to replace, I just cant seem to find the right file to change.
15 years 8 months ago #82008
The easiest way to override Kunena CSS is to put the changes into your Joomla site template CSS. Only you know what that's called and where it's located.
The following user(s) said Thank You: Toolcrazy
15 years 8 months ago - 15 years 1 month ago #82010
by TauxFu
Oh i've been all over that file already. I just can't find what changes it.
Joomla Template - Template.css
Maybe I'm missing some colour code from the default kunena template.
Should I be trying to change this in the html?
body {
font-family: Tahoma, Verdana, Arial, sans-serif;
line-height: 1.3em;
margin: 0;
padding: 0;
font-size: 12px;
color: #6A6A6A;
background: #fff;
body.contentpane {
background: #fff;
form {
margin: 0;
padding: 0;
img,table {
border: none;
p {
margin: 5px 0;
text-align: justify;
a {
color: #066;
outline: none;
text-decoration: none;
font-weight: 400;
a:link {
font-weight: 400;
a:visited {
font-weight: 400;
color: #066;
a:hover {
text-decoration: underline;
font-weight: 400;
input {
color: #066;
outline: none;
margin: 0;
input:focus {
outline: none;
button {
color: #fff;
font-size: 11px;
border: none;
background: #696969;
cursor: pointer;
#modlgn_remember.inputbox {
background: none;
border: none;
width: auto;
vertical-align:middle;
input.button, .validate {
color: #fff;
font-size: 11px;
cursor: pointer;
font-weight: 700;
border: none;
height:20px;
line-height:19px;
padding: 2px 4px 4px;
margin:6px 0 0 0;
/*** Template specific layout elements ***/
#page_bg {
background: #fff url(../images/page_bg.png) repeat-x top left;
#wrapper {
margin:0 auto;
width:980px;
#holder {
width:980px;
margin:0 auto;
#header {
position:relative;
margin:0 auto;
padding:24px 22px 43px 22px;
height:223px;
width:936px;
background: transparent url(../images/headerimg.jpg) no-repeat top center;
#pillmenu {
height:28px;
width:956px;
padding:0 12px;
margin:0 0 16px 0;
background: transparent url(../images/t_menu_bg.png) no-repeat top center;
#pillmenu ul {
overflow: hidden;
padding:0;
margin:0;
height:28px;
list-style: none;
#pillmenu li {
float: left;
#pillmenu li a {
float:left;
color: #fff;
font-weight: 700;
height:28px;
line-height:27px;
padding: 0 12px;
margin:0;
cursor:pointer;
background: transparent url(../images/t_menu_divider.png) no-repeat top right;
#pillmenu li a:hover, #pillmenu li a#active_menu-nav {
color:#006666;
background: transparent url(../images/t_menu_hover.png) no-repeat top right;
.logo {
float:left;
width:710px;
height:48px;
padding:4px 0 0 22px;
margin:0 0 4px 0;
overflow:hidden;
.logo table {
overflow:hidden;
width:710px;
height:48px;
.logo table td{
margin:0;
padding:0;
.logo h1 {
text-align:left;
color:#fff;
line-height:normal;
margin:0;
text-transform:capitalize;
.logo a, .logo a:link, .logo a:visited {
color:#fff;
font-size:20px;
font-weight:700;
text-decoration:none;
.logo a:hover {
font-weight:700;
.newsflash {
height:123px;
width:600px;
padding:50px 42px;
text-align:justify;
background: transparent url(../images/news_bg.png) no-repeat top left;
overflow:hidden;
.newsflash h3 {
width:600px;
height:17px;
color:#fff;
overflow:hidden;
line-height:17px;
margin:0 0 27px 0;
padding:4px;
text-align:left;
background: transparent url(../images/news_h3_bg.png) no-repeat bottom left;
.newsflash table tr td {
color:#C7D8D8;
height:78px;
text-align:justify;
.newsflash a {
color:#C7D8D8;
font-weight:700;
text-decoration:underline;
.newsflash a:hover {
color:#fff;
font-weight:700;
.newsflash div.module {
background:none;
width:600px;
height:118px;
margin:0 auto;
overflow:hidden;
.newsflash div.module div {
background:none;
padding:0;
.newsflash table.contentpaneopen {
margin:0;
.newsflash div.module_menu div div div, .newsflash div.module div div div, .newsflash div.module_text div div div {
margin:0;
padding:0;
.cpathway {
position:absolute;
bottom:0;
left:12px;
height:20px;
line-height:19px;
width:952px;
overflow:hidden;
.cpathway img {
float:left;
padding:6px 6px 0 0;
span.breadcrumbs.pathway {
float:left;
padding:0;
color:#066;
margin:0;
span.breadcrumbs.pathway a.pathway {
float:left;
margin:0;
padding:0 6px 0 0;
color: #2b2b2b;
font-weight:400;
span.breadcrumbs.pathway a.pathway:hover {
#search {
float:right;
padding:14px 0 0 0;
.search {
float:left;
height:32px;
padding:0 0 0 10px;
background:transparent url(../images/inputbox.png) no-repeat top left;
.search .inputbox {
float:left;
border: none;
color: #C7D8D8;
font-size:11px;
line-height:14px;
height:14px;
width:168px;
padding:8px 6px 9px 2px;
margin:0;
background:none;
.search .button {
float:left;
margin:0;
padding:0;
border:none;
text-indent:-9999px;
height:32px;
width:36px;
background:transparent url(../images/search_but.png) no-repeat top right;
.search .button:hover {
color:#e54d30;
#content {
margin:0 auto;
width:980px;
#leftcolumn, #rightcolumn {
float: left;
width: 220px;
padding:0;
margin:0 12px 10px 0;
#rightcolumn {
float: right;
margin:0 0 10px 12px;
div#maincolumn {
float: left;
padding:10px 10px 20px;
margin:0 0 12px 0;
width:496px;
background:#EDEFF0;
div#maincolumn_full {
margin:0 auto 10px;
width: 960px;
background:#EDEFF0;
div#maincolumn_left, div#maincolumn_right {
float: left;
margin:0 0 12px 0;
width: 728px;
background:#EDEFF0;
padding:6px 9px 10px 10px;
div.nopad {
overflow: hidden;
div.nopad ul {
clear: both;
td.middle_pad {
width: 20px;
#footer {
height:70px;
text-align:center;
margin:0 0 20px;
background: transparent url(../images/footer.png) no-repeat top center;
#footer_holder {
height:36px;
width:956px;
color: #fff;
font-weight:400;
line-height: 35px;
padding:0 12px;
margin:0 auto;
overflow:hidden;
#footer a {
color: #fff;
font-weight:400;
#footer a:hover {
a.footer123:link, a.footer123:visited {
color: #000;
font-family: Tahoma, Arial, sans-serif;
#f123 {
text-align: right;
width: 100%;
margin: 0 auto;
.f123 {
text-align: right;
.f123_bg {
background:url(../images/123_bg.png);
width:134px;
height:30px;
text-align:center;
padding: 0 3px;
.f123_1 {
display: block;
font-size: 10px;
color: #066;
text-align: left;
padding: 0 0 2px 4px;
a.link_123:link, a.link_123:visited {
font-size: 15px;
font-family: Tahoma, Verdana,Arial,Helvetica,sans-serif;
color: #066;
font-weight: 700;
a.link_123:hover {
font-size: 15px;
color: #fff;
font-weight: 700;
/*** Joomla! specific content elements ***/
div.offline {
background: #fffebb;
width: 100%;
position: absolute;
top: 0;
left: 0;
font-size: 1.2em;
padding: 5px;
/* headers */
div.componentheading {
height: 22px;
margin:0;
color: #000;
table.blog {
h1 {
padding: 0;
font-size: 1.3em;
line-height:19px;
font-weight: 700;
vertical-align: bottom;
color: #000;
text-align: left;
width: 100%;
h2, .contentheading {
padding: 0;
font-size: 14px;
vertical-align: middle;
color: #193e3e;
text-align: left;
font-weight: 700;
h2, a.contentheading {
background: none;
border: none;
margin:6px 0;
table.contentpaneopen h3 {
margin-top: 25px;
color:#585858;
h4 {
color: #333;
h3, .componentheading, table.moduletable th, legend {
margin:6px 0;
font-size: 12px;
font-weight:700;
text-align: left;
text-transform:uppercase;
color: #333;
padding: 0;
/* small text */
.small {
font-size: 10px;
color: #666666;
font-weight: 700;
text-align: left;
.modifydate {
height: 20px;
font-size: 10px;
color: #666666;
text-align: right;
.createdate {
vertical-align: top;
font-size: 11px;
color: #999;
padding-bottom: 8px;
a.readon {
float: right;
line-height: normal;
font-size: 11px;
padding: 0 0 0 14px;
color: #666666;
text-transform: lowercase;
a.readon:hover {
/* form validation */
.invalid { border-color: #ff0000; }
label.invalid { color: #ff0000; }
/** overlib **/
.ol-foreground {
background-color: #f1f1f1;
color: #333;
.ol-background {
color: #333;
.ol-textfont {
font-size: 10px;
.ol-captionfont {
font-size: 12px;
color: #fbfbfb;
font-weight: 700;
.ol-captionfont a {
color: #333;
font-size: 12px;
.ol-closefont {}
/* menu links */
a.mainlevel:link, a.mainlevel:visited {
padding-left: 5px;
a.mainlevel:hover {
/* spacers */
span.article_separator {
display: block;
height: 20px;
.article_column {
.column_separator {
td.buttonheading {
text-align: right;
width: 0;
.clr {
clear: both;
font-size:0;
table.blog span.article_separator {
display: block;
height: 20px;
/* table of contents */
table.contenttoc {
margin: 5px;
padding: 5px;
background: none;
table.contenttoc td {
padding: 0 5px;
/* content tables */
td.sectiontableheader {
color: #fff;
font-weight: 700;
padding: 4px;
tr.sectiontableentry1 td {
padding: 4px;
tr.sectiontableentry1 {
background:#edeff0;
tr.sectiontableentry0 td,
tr.sectiontableentry2 td {
padding: 4px;
td.sectiontableentry0,
td.sectiontableentry1,
td.sectiontableentry2 {
padding: 3px;
font-size: 11px;
/* content styles */
.contentpaneopen, table.contentpane {
margin: 0;
padding: 0;
table.contentpane td{
text-align: left;
table.contentpane td.contentdescription {
width: 100%;
table.contentpane {
text-align: left;
float: left;
width: 100%;
table.contentpane ul li a .category {
color: #FF8800;
table.contentpane ul li {
color: #666;
border-collapse: collapse;
padding: 0;
margin:0 6px;
table.contentpaneopen li {
margin-bottom: 5px;
table.contentpaneopen fieldset {
border: 0;
border-top: 1px solid #669933;
margin-top: 25px;
table.contentpaneopen h4 {
color: #000;
.highlight {
background-color: #990066;
ul.latestnews, ul.mostread {
list-style:none;
padding:0;
margin:0;
text-align:left;
/* module control elements */
table.user1user2 div.moduletable {
margin-bottom: 0px;
div.moduletable, div.module {
margin-bottom: 25px;
div.module_menu, div.module, div.module_text{
margin:0 0 10px 0;
padding: 0;
div.module_menu div, div.module div, div.module_text div {
margin:0;
background: transparent url(../images/box_m.png) repeat-y top center;
div.module_menu div div, div.module div div, div.module_text div div {
text-align: center;
margin:0;
padding:0 0 3px 0;
background: transparent url(../images/box_b.png) no-repeat bottom center;
div.module_menu div div div, div.module div div div, div.module_text div div div {
padding:0 0 14px 0;
margin:0 auto;
color:#605d6f;
background: transparent url(../images/box_t.png) no-repeat top center;
div.module div div div div {
width: 160px;
color:#605d6f;
div.module_menu div div div div, div.module div div div div, div.module_text div div div div {
background: none;
margin:0 auto;
padding:0;
color:#605d6f;
text-align: left;
div.module_text div div div div.bannergroup_text {
padding: 10px 10px 10px 20px;
width: 174px;
div.module_text div div div div.bannergroup_text div {
color:#605d6f;
width: auto;
padding: 0 0 4px;
div.module div div div form {
margin:0 auto;
padding:0 0 6px 20px;
text-align:left;
width:180px;
div.module_menu ul {
list-style: none;
padding: 0;
div.module_menu ul#mainlevel {
margin: 0 auto;
text-align: center;
div.module_menu ul li{
margin: 0;
padding: 0;
div.module_menu ul li a:link, div.module_menu ul li a:visited {
font-weight: 700;
padding: 2px 0;
line-height: 24px;
background: transparent url(../images/blue/bullet2.jpg) top left no-repeat;
#leftcolumn div.module table ,#rightcolumn div.module table {
padding: 0 0 6px 0;
#leftcolumn div.module table td ,#rightcolumn div.module table td {
margin:0;
padding: 0 6px 0 0;
height:20px;
color:#c7d8d8;
text-align:left;
line-height:13px;
#leftcolumn div.module table.poll {
#leftcolumn div.module table.poll td {
text-align: left;
/* LEFT COL H3 */
#leftcolumn h3, #rightcolumn h3 {
width:196px;
height: 31px;
line-height:30px;
margin:0 0 6px 0;
padding: 0 12px;
font-size: 11px;
color: #c7d8d8;
text-align: left;
text-transform:none;
font-weight: 700;
overflow:hidden;
background: transparent url(../images/box_h3.png) no-repeat top center;
#rightcolumn h3 {
.moduletable_menu, .moduletable, .moduletable_text {
margin: 0 0 16px 0;
padding: 0 0 8px 0;
#leftcolumn ul.menu, #rightcolumn ul.menu {
list-style: none;
text-align: left;
margin:0;
width:198px;
padding:0 0 0 12px;
#leftcolumn ul.menu li, #rightcolumn ul.menu li {
margin:0 0 1px 0;
#leftcolumn ul.menu li:hover, #rightcolumn ul.menu li:hover {
#leftcolumn ul.menu li ul li, #rightcolumn ul.menu li ul li {
/*LEFT COL LINK*/
#leftcolumn ul.menu li a, #leftcolumn ul.menu li a:link,
#rightcolumn ul.menu li a, #rightcolumn ul.menu li a:link {
display:block;
font-weight: 400;
font-size: 11px;
line-height: 19px;
padding:0 0 0 14px;
color: #605d6f;
background: transparent url(../images/menu_arrow.gif) no-repeat left top;
#leftcolumn ul.menu li a:hover, #rightcolumn ul.menu li a:hover {
color: #000;
background: transparent url(../images/menu_arrow_hover.gif) no-repeat left top;
/*LEFT COL CURRENT LINK*/
#leftcolumn ul.menu li#current, #rightcolumn ul.menu li#current {
#leftcolumn ul.menu li#current a, #leftcolumn ul.menu li#current a:link,
#rightcolumn ul.menu li#current a, #rightcolumn ul.menu li#current a:link {
display:block;
color: #000;
#leftcolumn ul.menu li#current {
#leftcolumn ul.menu li#current a:hover, #rightcolumn ul.menu li#current a:hover {
display:block;
color: #000;
/*LEFT COL SUB LINK*/
#leftcolumn ul.menu li#current ul li a, #leftcolumn ul.menu li#current ul li a:link,
#rightcolumn ul.menu li#current ul li a, #rightcolumn ul.menu li#current ul li a:link {
font-weight: 400;
color: #605d6f;
line-height:19px;
padding:0 0 0 14px;
background: none;
#leftcolumn ul.menu li#current ul li a:hover, #rightcolumn ul.menu li#current ul li a:hover {
color: #000;
background: none;
#leftcolumn ul.menu li ul li#current, #rightcolumn ul.menu li ul li#current {
#leftcolumn ul.menu li.parent ul li, #rightcolumn ul.menu li.parent ul li {
#leftcolumn ul.menu li.parent ul li a,
#rightcolumn ul.menu li.parent ul li a {
line-height:19px;
font-size: 11px;
font-weight: 400;
color: #605d6f;
padding:0 0 0 14px;
background: none;
#leftcolumn ul.menu li.parent ul li a:hover {
color: #000;
background: none;
/*SUBMENU POSITION*/
#leftcolumn ul.menu li#current ul {
margin: 0;
padding: 0;
#leftcolumn ul.menu li#current ul li {
margin: 0;
padding: 0;
/*CURRENT SUBMENU POSITION*/
#leftcolumn ul.menu li ul {
margin: 0;
padding: 0;
#leftcolumn ul.menu li ul, #rightcolumn ul.menu li ul {
list-style: none;
margin:0;
/* forms */
#leftcolumn .moduletable ul, #rightcolumn .moduletable ul {
margin: 6px 0;
padding: 0;
list-style: none;
#leftcolumn .moduletable ul li, #rightcolumn .moduletable ul li {
margin: 0;
padding: 0 2px;
table.adminform textarea {
width: 540px;
height: 400px;
font-size: 1em;
color: #066;
form#form-login fieldset {
border: 0 none;
padding: 0;
margin:0;
color:#605d6f;
text-align: left;
form#form-login ul {
padding: 0;
list-style: none;
text-align: left;
margin: 10px auto 0;
form#form-login ul li {
padding: 0;
form#form-login ul li a {
text-align: left;
padding: 0;
font-size: 11px;
color: #605d6f;
form#form-login ul li a:hover {
#form-login input {
border:none;
color:#000;
font-size:11px;
height:14px;
line-height:14px;
padding:2px 4px;
background:#becccd;
input#modlgn_passwd, input#modlgn_username {
width:142px;
input.button, #form-login input.button {
height:20px;
border:none;
font-weight:700;
color:#becccd;
line-height:15px;
padding:2px 6px 3px;
background:transparent url(../images/but.gif) repeat-x top left;
input.button:hover, #form-login input.button:hover {
color:#fff;
/* thumbnails */
div.mosimage { margin: 5px; }
div.mosimage_caption { font-size: .90em; color: #333; }
div.caption { padding: 0 10px 0 10px; }
div.caption img { border: 1px solid #CCC; }
div.caption p { font-size: .90em; color: #333; text-align: center; }
/* Parameter Table */
table.paramlist {
margin-top: 5px;
table.paramlist td.paramlist_key {
width: 128px;
text-align: left;
height: 30px;
table.paramlist td.paramlist_value {
div.message {
font-weight: 700;
font-size : 14px;
color : #c30;
text-align: center;
width: auto;
background-color: #f9f9f9;
border: solid 1px #d5d5d5;
margin: 3px 0px 10px;
padding: 3px 20px;
/* Banners module */
/* Default skyscraper style */
.bannergroup {
.banneritem {
/* Text advert style */
.banneritem_text {
padding: 4px;
font-size: 11px;
.banneritem_text a {
font-weight:700;
color:#000;
.bannerfooter_text {
padding: 4px;
font-size: 11px;
text-align: right;
/* System Messages */
/* see system general.css */
.pagination span { padding: 2px; }
.pagination a { padding: 2px; }
/* Polls */
.pollstableborder td {
text-align: left;
/* Frontend Editing*/
fieldset {
border: 1px solid #ccc;
margin-top: 15px;
padding: 4px;
legend {
margin: 0;
padding: 0 10px;
td.key {
border-bottom:1px solid #eee;
color: #333;
/* Tooltips */
.tool-tip {
float: left;
background: #ffc;
border: 1px solid #D4D5AA;
padding: 5px;
max-width: 200px;
.tool-title {
padding: 0;
margin: 0;
font-size: 100%;
font-weight: 700;
margin-top: -15px;
padding-top: 15px;
padding-bottom: 5px;
background: url(../../system/images/selector-arrow.png) no-repeat;
.tool-text {
font-size: 100%;
margin: 0;
/* System Standard Messages */
#system-message dd.message ul {
padding: 0;
margin: 0;
background: none;
border: none;
/* System Error Messages */
#system-message dd.error ul {
color: #c00;
background: none;
border: none;
padding: 0;
margin: 0;
/* System Notice Messages */
#system-message dd.notice ul {
color: #c00;
background: none;
border: none;
padding: 0;
margin: 0;
#system-message dd {
text-indent: 0;
#system-message dd ul {
list-style-type: none;
color: #c00;
background: none;
border: none;
#system-message {
margin-top: 5px;
/* fix */
.nopad fieldset {
float:left;
border:none;
padding:0;
margin:0 0 30px;
.nopad fieldset p {
margin:0 0 10px;
overflow:hidden;
.nopad fieldset label {
float: left;
.nopad fieldset input {
float:left;
.nopad fieldset #remember {
margin:0 0 0 10px;
/* fix */
line-height: 1.3em;
margin: 0;
padding: 0;
font-size: 12px;
color: #6A6A6A;
background: #fff;
body.contentpane {
background: #fff;
form {
margin: 0;
padding: 0;
img,table {
border: none;
p {
margin: 5px 0;
a {
color: #066;
outline: none;
font-weight: 400;
a:link {
font-weight: 400;
a:visited {
font-weight: 400;
color: #066;
a:hover {
font-weight: 400;
input {
color: #066;
outline: none;
margin: 0;
input:focus {
outline: none;
button {
color: #fff;
font-size: 11px;
border: none;
cursor: pointer;
background: none;
border: none;
width: auto;
color: #fff;
font-size: 11px;
cursor: pointer;
font-weight: 700;
border: none;
height:20px;
line-height:19px;
margin:6px 0 0 0;
#page_bg {
#wrapper {
margin:0 auto;
width:980px;
#holder {
width:980px;
margin:0 auto;
#header {
position:relative;
margin:0 auto;
height:223px;
width:936px;
#pillmenu {
height:28px;
width:956px;
padding:0 12px;
margin:0 0 16px 0;
#pillmenu ul {
overflow: hidden;
padding:0;
margin:0;
height:28px;
list-style: none;
#pillmenu li {
float: left;
#pillmenu li a {
float:left;
color: #fff;
font-weight: 700;
height:28px;
line-height:27px;
padding: 0 12px;
margin:0;
cursor:pointer;
color:#006666;
.logo {
float:left;
width:710px;
height:48px;
margin:0 0 4px 0;
overflow:hidden;
.logo table {
overflow:hidden;
width:710px;
height:48px;
.logo table td{
margin:0;
padding:0;
.logo h1 {
text-align:left;
color:#fff;
line-height:normal;
margin:0;
color:#fff;
font-size:20px;
font-weight:700;
.logo a:hover {
font-weight:700;
.newsflash {
height:123px;
width:600px;
padding:50px 42px;
text-align:justify;
overflow:hidden;
.newsflash h3 {
width:600px;
height:17px;
color:#fff;
overflow:hidden;
line-height:17px;
margin:0 0 27px 0;
padding:4px;
text-align:left;
color:#C7D8D8;
height:78px;
text-align:justify;
.newsflash a {
color:#C7D8D8;
font-weight:700;
color:#fff;
font-weight:700;
background:none;
width:600px;
height:118px;
margin:0 auto;
overflow:hidden;
background:none;
padding:0;
margin:0;
margin:0;
padding:0;
.cpathway {
position:absolute;
bottom:0;
left:12px;
height:20px;
line-height:19px;
width:952px;
overflow:hidden;
.cpathway img {
float:left;
float:left;
padding:0;
color:#066;
margin:0;
float:left;
margin:0;
padding:0 6px 0 0;
color: #2b2b2b;
font-weight:400;
#search {
float:right;
padding:14px 0 0 0;
.search {
float:left;
height:32px;
padding:0 0 0 10px;
.search .inputbox {
float:left;
border: none;
color: #C7D8D8;
font-size:11px;
line-height:14px;
height:14px;
width:168px;
margin:0;
background:none;
.search .button {
float:left;
margin:0;
padding:0;
border:none;
height:32px;
width:36px;
color:#e54d30;
#content {
margin:0 auto;
width:980px;
float: left;
width: 220px;
padding:0;
#rightcolumn {
float: right;
div#maincolumn {
float: left;
margin:0 0 12px 0;
width:496px;
background:#EDEFF0;
margin:0 auto 10px;
width: 960px;
background:#EDEFF0;
float: left;
margin:0 0 12px 0;
width: 728px;
background:#EDEFF0;
div.nopad {
overflow: hidden;
div.nopad ul {
clear: both;
td.middle_pad {
width: 20px;
#footer {
height:70px;
text-align:center;
margin:0 0 20px;
#footer_holder {
height:36px;
width:956px;
color: #fff;
font-weight:400;
line-height: 35px;
padding:0 12px;
margin:0 auto;
overflow:hidden;
#footer a {
color: #fff;
font-weight:400;
#footer a:hover {
color: #000;
#f123 {
text-align: right;
width: 100%;
margin: 0 auto;
.f123 {
text-align: right;
.f123_bg {
width:134px;
height:30px;
text-align:center;
padding: 0 3px;
.f123_1 {
display: block;
font-size: 10px;
color: #066;
text-align: left;
font-size: 15px;
color: #066;
font-weight: 700;
a.link_123:hover {
font-size: 15px;
color: #fff;
font-weight: 700;
div.offline {
width: 100%;
position: absolute;
top: 0;
left: 0;
font-size: 1.2em;
padding: 5px;
/* headers */
height: 22px;
margin:0;
color: #000;
table.blog {
h1 {
padding: 0;
font-size: 1.3em;
line-height:19px;
font-weight: 700;
color: #000;
text-align: left;
width: 100%;
padding: 0;
font-size: 14px;
color: #193e3e;
text-align: left;
font-weight: 700;
background: none;
border: none;
margin:6px 0;
margin-top: 25px;
color:#585858;
h4 {
color: #333;
margin:6px 0;
font-size: 12px;
font-weight:700;
text-align: left;
color: #333;
padding: 0;
/* small text */
.small {
font-size: 10px;
color: #666666;
font-weight: 700;
text-align: left;
.modifydate {
height: 20px;
font-size: 10px;
color: #666666;
text-align: right;
.createdate {
font-size: 11px;
color: #999;
a.readon {
float: right;
font-size: 11px;
color: #666666;
a.readon:hover {
/** overlib **/
.ol-foreground {
color: #333;
.ol-background {
color: #333;
.ol-textfont {
font-size: 10px;
.ol-captionfont {
font-size: 12px;
color: #fbfbfb;
font-weight: 700;
.ol-captionfont a {
color: #333;
font-size: 12px;
.ol-closefont {}
/* menu links */
padding-left: 5px;
a.mainlevel:hover {
/* spacers */
display: block;
height: 20px;
.article_column {
.column_separator {
td.buttonheading {
text-align: right;
width: 0;
.clr {
clear: both;
font-size:0;
display: block;
height: 20px;
table.contenttoc {
margin: 5px;
padding: 5px;
background: none;
padding: 0 5px;
color: #fff;
font-weight: 700;
padding: 4px;
padding: 4px;
background:#edeff0;
padding: 4px;
padding: 3px;
font-size: 11px;
margin: 0;
padding: 0;
text-align: left;
width: 100%;
table.contentpane {
text-align: left;
float: left;
width: 100%;
color: #FF8800;
color: #666;
padding: 0;
margin:0 6px;
margin-bottom: 5px;
border: 0;
margin-top: 25px;
color: #000;
.highlight {
list-style:none;
padding:0;
margin:0;
text-align:left;
margin-bottom: 0px;
margin:0 0 10px 0;
padding: 0;
margin:0;
text-align: center;
margin:0;
padding:0 0 3px 0;
padding:0 0 14px 0;
margin:0 auto;
color:#605d6f;
width: 160px;
color:#605d6f;
background: none;
margin:0 auto;
padding:0;
color:#605d6f;
text-align: left;
width: 174px;
color:#605d6f;
width: auto;
padding: 0 0 4px;
margin:0 auto;
text-align:left;
width:180px;
list-style: none;
padding: 0;
margin: 0 auto;
text-align: center;
margin: 0;
padding: 0;
font-weight: 700;
padding: 2px 0;
line-height: 24px;
padding: 0 0 6px 0;
margin:0;
padding: 0 6px 0 0;
height:20px;
color:#c7d8d8;
text-align:left;
line-height:13px;
text-align: left;
/* LEFT COL H3 */
width:196px;
height: 31px;
line-height:30px;
margin:0 0 6px 0;
padding: 0 12px;
font-size: 11px;
color: #c7d8d8;
text-align: left;
font-weight: 700;
overflow:hidden;
#rightcolumn h3 {
margin: 0 0 16px 0;
padding: 0 0 8px 0;
list-style: none;
text-align: left;
margin:0;
width:198px;
padding:0 0 0 12px;
margin:0 0 1px 0;
/*LEFT COL LINK*/
display:block;
font-weight: 400;
font-size: 11px;
line-height: 19px;
padding:0 0 0 14px;
color: #605d6f;
color: #000;
display:block;
color: #000;
display:block;
color: #000;
font-weight: 400;
color: #605d6f;
line-height:19px;
padding:0 0 0 14px;
background: none;
color: #000;
background: none;
line-height:19px;
font-size: 11px;
font-weight: 400;
color: #605d6f;
padding:0 0 0 14px;
background: none;
color: #000;
background: none;
margin: 0;
padding: 0;
margin: 0;
padding: 0;
margin: 0;
padding: 0;
list-style: none;
margin:0;
/* forms */
margin: 6px 0;
padding: 0;
list-style: none;
margin: 0;
padding: 0 2px;
width: 540px;
height: 400px;
font-size: 1em;
color: #066;
border: 0 none;
padding: 0;
margin:0;
color:#605d6f;
text-align: left;
padding: 0;
list-style: none;
text-align: left;
padding: 0;
text-align: left;
padding: 0;
font-size: 11px;
color: #605d6f;
#form-login input {
border:none;
color:#000;
font-size:11px;
height:14px;
line-height:14px;
padding:2px 4px;
background:#becccd;
width:142px;
height:20px;
border:none;
font-weight:700;
color:#becccd;
line-height:15px;
color:#fff;
/* thumbnails */
table.paramlist {
margin-top: 5px;
width: 128px;
text-align: left;
height: 30px;
div.message {
font-weight: 700;
font-size : 14px;
color : #c30;
text-align: center;
width: auto;
padding: 3px 20px;
.bannergroup {
.banneritem {
.banneritem_text {
padding: 4px;
font-size: 11px;
font-weight:700;
color:#000;
padding: 4px;
font-size: 11px;
text-align: right;
/* Polls */
text-align: left;
fieldset {
margin-top: 15px;
padding: 4px;
legend {
margin: 0;
padding: 0 10px;
td.key {
color: #333;
/* Tooltips */
.tool-tip {
float: left;
background: #ffc;
padding: 5px;
max-width: 200px;
.tool-title {
padding: 0;
margin: 0;
font-size: 100%;
font-weight: 700;
margin-top: -15px;
padding-top: 15px;
.tool-text {
font-size: 100%;
margin: 0;
padding: 0;
margin: 0;
background: none;
border: none;
color: #c00;
background: none;
border: none;
padding: 0;
margin: 0;
color: #c00;
background: none;
border: none;
padding: 0;
margin: 0;
text-indent: 0;
color: #c00;
background: none;
border: none;
#system-message {
margin-top: 5px;
/* fix */
.nopad fieldset {
float:left;
border:none;
padding:0;
margin:0 0 30px;
.nopad fieldset p {
margin:0 0 10px;
overflow:hidden;
float: left;
float:left;
margin:0 0 0 10px;
/* fix */
Last edit: 15 years 1 month ago by Matias.
