- Thank you received: 3
Question Need Help Fixing Template
- freedomcoach
- Premium Member
15 years 11 months ago #74250
by freedomcoach
Need Help Fixing Template was created by freedomcoach
Hi Everyone:
A tech guy installed the Wordpress for Joomla component today for me and it caused all kinds of problems. I managed to uninstall it and plugins, modules, etc and my site is functional once again but... one remnant damage is that my Kunena forum is now skewed over to the left. The template seems messed up.
What is the easiest way to fix this? Would it help to re-install Kunena or can I adjust this in some easier way?
Sincerely,
Howard
Sincerely,
Howard
The topic has been locked.
15 years 11 months ago #74251
by 810
Replied by 810 on topic Need Help Fixing Template
remove on your template css
.contentLayout .content-sidebar2
width:774px;
then the width is ok again.
Regards 810
width:774px;
Regards 810
- freedomcoach
- Premium Member
15 years 11 months ago - 15 years 11 months ago #74325
by freedomcoach
Replied by freedomcoach on topic Need Help Fixing Template
Thanks! Which CSS file do I need to modify? Some of them are presently marked unwritable in red which I did not see before. What is the easiest way to locate the exact text string in the file?
Incidentally, this issue exists widely throughout the site since the snaffu with the Wordpress component. Can I fix this on the entire site in some way by adjusting the CSS sitewide?
Sincerely,
Howard
Sincerely,
Howard
Last edit: 15 years 11 months ago by freedomcoach.
- freedomcoach
- Premium Member
15 years 11 months ago #74934
by freedomcoach
Could someone please help me with this template issue and let me know in which css file this needs to be adjusted? Much appreciated.
Sincerely,
Howard
Sincerely,
Howard
15 years 11 months ago #74951
Replied by sozzled on topic Need Help Fixing Template
I'll look into these issues for you. For the time being, however, your forum seems to be working OK (as far as I can tell in the couple of minutes that I spent at your site). The module assignment is something that you can fix using the Joomla Module Manager.
15 years 11 months ago #74956
You may need to create a different "site" template and use it just for Kunena. This might be a workaround solution. Your site template looks great, by the way, but it's not easy to make Kunena co-operate with it.
