Question Spacing in buttons
15 years 11 months ago #72330 by bgies
Spacing in buttons was created by bgies
I looked through a lot of this forum, but couldn't find this particular problem.
After installing 1.6.1 everything looks good except that the "buttons" have spaces in them. I'm assuming it is .css problem, but before I start fooling around I wanted to know if someone else has already solved this.
Joomla 1.5.21 Kunena 1.6.1
Here's the URL if you want to see it, or just view the screenshot:
nocrappyapps.com/index.php/forum/4-assoc.../11-first-steps.html
As far as I can tell it's only using Kunena classes, so it doesn't look like some other .css file is getting in the way.
These are the classes for the "Reply Topic" button: kicon-button kbuttoncomm btn-left
BUT... I don't see a class called btn-left anywhere... what file should it be in?
It doesn't happen on my test site. Anything else you need to know?
15 years 11 months ago - 15 years 11 months ago #72331 by sozzled
Replied by sozzled on topic Re: Spacing in buttons
We've seen this problem on occasion. One of the causes was when people upgraded from one of the earlier development versions of Kunena (see Forum buttons displaying incorrectly on frontend ).
Another cause was an incomplete or corrupted installation of Kunena 1.6.1 - reinstalling K 1.6.1 (there is no need to uninstall Kunena 1.6.1 before you do this) may solve the problem.
A more definitive answer is given in the discussion topic My buttons are not right... .
I hope this helps
Last edit: 15 years 11 months ago by sozzled.
The following user(s) said Thank You: bgies
15 years 11 months ago #72380 by bgies
Replied by bgies on topic Re: Spacing in buttons
Sorry... I guess it was a browser caching issue.. because this morning it is gone...
Thanks for the quick reply... and sorry for the basically useless post :).
