Question Formatting Problem
15 years 11 months ago #72019 by nsglazer
Formatting Problem was created by nsglazer
I'm new to Kunena. I am having a formatting problem with Kunena 1.6 - I have tried several template sets, but have had the problem with all of them. You can see my trouble here:
www.bahamaspilotchallenge.com/joomla/ind...nc=listcat&Itemid=62
Any clue what is causing this?
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 2M
Joomla default template details : theme292 | author: Trinity | version: 1.0.0 | creationdate: 20 May 2009
15 years 11 months ago - 15 years 11 months ago #72044 by @quila
Replied by @quila on topic Re: Formatting Problem
try to add this rule to your Main Joomla Template css file.
#Kunena {
overflow:hidden;
Best Regards
Last edit: 15 years 11 months ago by @quila.
The following user(s) said Thank You: nsglazer
15 years 11 months ago #72045 by nsglazer
Replied by nsglazer on topic Re: Formatting Problem
I added it, but it didn't help.
Neil
15 years 11 months ago #72047 by @quila
Hi Neil,
are you sure to add this to place I said, I can't see this rule on your site.
Check again: Joomla Default Template style css file, should be something like template.css
Clean also the cache if is enabled.
15 years 11 months ago #72052 by nsglazer
Cache has been cleaned out. I added it to the CSS found here:
/var/www/vhosts/bahamaspilotchallenge.com/httpdocs/joomla/templates/theme292/css/template.css
That's the one from the main template.
Is it somewhere else I need to add?
Neil
15 years 11 months ago #72053 by @quila
No I dont think so.
Now I see that you have added it to template.css and constant.css and forum show just fine without error on my end.
For you not?
Time to create page: 0.145 seconds
