Question problem with buttons on forum
16 years 1 week ago #70963 by ronnie_bex
hi all ,
I created my first forum with joomla & kunena ...
Creating the forum is no problem but for some reason the buttons are scrammbeld on every forum page ... and not only on my pc but on every geust & member .
find attached a file showing the problem
Does anyone has an idea what I can do to have this cleaned up ?
16 years 1 week ago #70964 by Mortti
Do you use some custom button set (for K template)? or maybe your template do that...? have you tested with defaulf J! and K template this issue...?
Components -- Kunena Forum -- Report Configuration Settings help also these moderators here a lot, I think... use also forum search, if I remember right this is old issue...
16 years 1 week ago #71031 by ronnie_bex
i tested this morning with the default template and this was ok ....
Will try to find a new template not causing this problem !
thx for your help !
