Question Scroll bar in topic
16 years 1 month ago #66863 by WorLox
Scroll bar in topic was created by WorLox
Can anybody tell me how to remove the scroll bar in a topic.
Or is this not possible.
16 years 1 month ago #66864 by sozzled
Replied by sozzled on topic Scroll bar in topic
Does this issue occur here, at Kunena.com, or just with your own website? If this issue occurs here, at Kunena.com, can you do two things?
(1) Show an example of where this occurs - a screnshot will help
(2) Provide details of the web browser that you are using to view the pages at Kunena.com
16 years 1 month ago - 16 years 1 month ago #67352 by WorLox
Replied by WorLox on topic Scroll bar in topic
No i have it in my own forum.
You can check the forum at www.spuij-design.com , check the first topic in suggestion box.
I really cant seem to find where to remove that, or if its even possible.
I hope somebody can help me.
The browser this problem occurs in is Chrome.
Explorer doesnt seem to have the problem.
Template Used: own template.
WorLox..
Last edit: 16 years 1 month ago by WorLox.
16 years 1 month ago - 16 years 1 month ago #67361 by sozzled
Change your Kunena template CSS as indicated in red below
#Kunena div.kmsgbody div.kmsgtext {
overflow:hidden;
word-wrap:break-word;
I notice that you are not using minified CSS in your Kunena forum. You must be running with Kunena with debug mode enabled. You can improve performance by using minified CSS and turning Kunena debug mode off.
Last edit: 16 years 1 month ago by sozzled.
16 years 1 month ago #67372 by WorLox
Hey There,
I am using an istalled template, i am creating at the moment.
Your correct to say that no minified css is used, that is because it was and still is in Debug mode, i like to change on the fly checking what im doing.
I always create the mini. after the changes i made.
I have changed the overflow to hidden, but it didn't help me.
Do you have any other idea's ??.
Thnx.
16 years 1 month ago #67374 by sozzled
I had another look at your page - I force refreshed my browser cache, too.
Your Kunena Template CSS shows
overflow:auto;
You need to change it as I showed above. I cannot test with Google Chrome; I use Firefox (and occasionally IE8)
The following user(s) said Thank You: WorLox
