Question Scroll bar in topic
Or is this not possible.
(1) Show an example of where this occurs - a screnshot will help
(2) Provide details of the web browser that you are using to view the pages at Kunena.com
You can check the forum at www.spuij-design.com , check the first topic in suggestion box.
I really cant seem to find where to remove that, or if its even possible.
I hope somebody can help me.
The browser this problem occurs in is Chrome.
Explorer doesnt seem to have the problem.
Template Used: own template.
WorLox..
#Kunena div.kmsgbody div.kmsgtext {
overflow:hidden;
word-wrap:break-word;
I notice that you are not using minified CSS in your Kunena forum. You must be running with Kunena with debug mode enabled. You can improve performance by using minified CSS and turning Kunena debug mode off.
I am using an istalled template, i am creating at the moment.
Your correct to say that no minified css is used, that is because it was and still is in Debug mode, i like to change on the fly checking what im doing.
I always create the mini. after the changes i made.
I have changed the overflow to hidden, but it didn't help me.
Do you have any other idea's ??.
Thnx.
Your Kunena Template CSS shows
overflow:auto;
You need to change it as I showed above. I cannot test with Google Chrome; I use Firefox (and occasionally IE8)
