Question Grey boxes and white letters dont work,how can I change color of the grey box?
- Pixelsmiths
16 years 5 days ago #62863
by Pixelsmiths
Grey boxes and white letters dont work,how can I change color of the grey box? was created by Pixelsmiths
Hello
Once again I want to ask for your advice.
We have these two grey boxes appeairng on the forum. The grey color and white font clash.
The first one is on the profile page (look at Grey Box)
and the second is on the posts that friends made (when you scroll down from the profile page,Grey Box 2)
Any help please?
Any help please?
- Pixelsmiths
16 years 4 days ago #62986
by Pixelsmiths
Replied by Pixelsmiths on topic Re: Grey boxes and white letters dont work,how can I change color of the grey box?
I know you guys dont always see the posts so im just giving mine a little bump.
- Nihil
16 years 4 days ago #63019
by Nihil
Replied by Nihil on topic Re: Grey boxes and white letters dont work,how can I change color of the grey box?
1) Download Firefox
2) Install the Firebug plugin
2.1)
2.2) vimeo.com/3087755
3) Find the feature "Inspect Element"
4) Poke around your site with that until you find the element that defines what you want to change.
5) Change the element IN Firebug to see what the change will look like
6) Open the template.css file that is the theme of your whole site. i recommend NotePad++ for this
7) Add/change the bits of code that will change Kunena to that template. But change it in the site template.
The code below is what i did to solve the same problem you had. Remember, this goes in the template running your whole site. Leave the Kunena templates alone. The site template will override the Kunena template.
/* Use comments to tell yourself what you are changing */
/* Or to remove lines of code without deleting them */
Thank Severdia when you get it working. He got me through this.
Some of these elements will change things you might not want changed, so you could try figuring out which you need first.
#Kunena tr.krow1 td
#Kunena tr.krow2 td
Are probably the most important to getting your site back on track.
Good luck!
2.1)
/* Change the link colors */
#Kunena a:link,
#Kunena a:visited,
#Kunena a:active {
color:#XXXXXX !important;
/* Change the header background colors */
#Kunena .kblock div.kheader {
background:none repeat scroll 0 0 #000000;
/* Change the header text colors */
#Kunena .kblock div.kheader h2 a:link,
#Kunena .kblock div.kheader h2 a:visited,
#Kunena .kblock div.kheader h2 a:active {
color: #fff !important;
/* Change the tab colors */
div#ktab ul.menu li a {
background-color: #444444 !important;
/* Change the active tab & rollover colors */
div#ktab li#current a {
div#ktab ul.menu li a:hover {
background-color: #YYYYYY !important;
/* Change the border color under the top nav */
#Kunena #ktop {
border-color: #YYYYYY;
/* Change the pagination color */
#Kunena .kpagination .active {
background:none repeat scroll 0 0 #XXXXXX;
border:1px solid #YYYYYY;
#Kunena .kpagination a {
border:1px solid #000000;
#Kunena .kpagination a:hover {
border:1px solid #YYYYYY ;
background: #XXXXXX;
/* Change the post link color */
#Kunena div.kmsg-header h2 a {
color: #000 !important;
/* Change the toggler color */
#Kunena #ktop span.ktoggler {
background-color:#444444;
/* Change the button rollover color */
#Kunena .kbutton:hover, #Kunena .kbutton:focus {
background-color: #XXXXXX;
/* This line turns kunena text black. Turning that off so the text will be white again.
#Kunena {
color: #000000;
/* Sets the thread title background color */
#Kunena tr.krow1 td {
background: none repeat scroll 0 0 #222222 !important;
/* Sets the alternating thread title background color */
#Kunena tr.krow2 td {
background: none repeat scroll 0 0 #333333 !important;
/* sets the background color of the threads! */
#Kunena div.kblock {
background: none repeat scroll 0 0 #000000 !important;
/* Not sure what this does yet */
#Kunena .krow2-stickymsg {
#Kunena .krow1-stickymsg {
#Kunena td.kprofile-left {
#Kunena .kwho-globalmoderator {
color: #FFFFFF !important;
font-weight: bold;
#Kunena tr.krow1 td
#Kunena tr.krow2 td
Good luck!
15 years 11 months ago #68423
by ovccrick
Replied by ovccrick on topic Re: Grey boxes and white letters dont work,how can I change color of the grey box?
This is absolutely so very cool and I thank you.
15 years 11 months ago #68428
Replied by sozzled on topic Re: Grey boxes and white letters dont work,how can I change color of the grey box?
That's one of the best tutorials about Firebug that I've seen. I think I'll write a tutorial in the Kunena Wiki to point to this.
15 years 8 months ago #82021
by TauxFu
Replied by TauxFu on topic Re: Grey boxes and white letters dont work,how can I change color of the grey box?
the codes you supplied helped me fix it all instantly. thanks soooo much.
Time to create page: 0.228 seconds
