Question Align child categories
I was using with my Kunena 1.5 a template that had all the child categories aligned in columns. My forum has lots of child categories because it's a sharing corner and there's a child category for each of the popular users, so it's pretty important having them aligned in the categories view, otherways it looks like a total mess.
Please it would be really helpful if someone can suggest me some CSS edit in order to align the child categories in columns.
Thanks,
Pau
In order to see the child categories you need to be registered (they're in the creators corner), so I'm posting a photo that way you don't need to register.
I'm using Kunena 1.6 RC1 with the template ArgentRC, but the CSS of this template is actually the same as the default one but with the colours changed and a new menu, so a modify of the child categories should be the same for the default template and for mine.
At first it looks difficult to set this on columns but as I said with Kunena 1.5 it was the same and I installed a template (I can't remember the name) that had this in columns, so probably it won't be that difficult.
#Kunena div.kcc-subcat {
display:inline-block;
float:left;
vertical-align:top;
ADD HERE: width:49%; or width:33%; or width:99%;
49% -> 2 COLUMNS, 33% -> 3 COLUMNS, 99% -> 1 Column.
WordPress Development and Kunena templates.
Above change should do it
