Solved How to change color of announcement setup in frontend
The reason that your announcements look like that has something to do with your Joomla site template. I suggest you read the article I have referred to and I hope it helps. Screenshots, to illustrate the problem, help, but nothing helps more than access to your website (and your configuration report will give us that information).
do you want the source of the theme ?
and it works
