Solved [Resolved] Text colour is the same as background colour. How to fix?
14 years 3 months ago - 14 years 1 month ago #120075 by SvSwebs
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 10M
Joomla default template details : aquarians3 | author: Svilen Stoyanov | version: 1.0 | creationdate: 2012-02-21
Kunena default template details : Example Template | author: Kunena Team | version: 1.7.2 | creationdate: 2012-01-31
Last edit: 14 years 1 month ago by sozzled. Reason: Change topic icon
14 years 3 months ago - 14 years 3 months ago #120079 by Jiminimonka
Hi SvSwebs, welcome to Kunena,
Thanks for posting your configuration report, however, the title of your post does not help explain what your issue is, so please post some detailed information to enable us to help, if possible.
One thing you should do is not use the Example Kunena template, that is to help template designers and is not intended to run on a live board. Use Blue Eagle (Default) instead.
Please read the FAQ.
Only one question per topic.
Last edit: 14 years 3 months ago by Jiminimonka.
The following user(s) said Thank You: SvSwebs
14 years 3 months ago #120080 by SvSwebs
hello agaian.thanks for the advice to use the Blue eagle menu,i have used the example one,as it appeared a bit smaller,and dint effect the visibility of the modules on the right ;)
Now to my issue.
>The posts backgrount is set to white color which is ok,and seems nice even with the template of my website,but when a post is add,or set it seems like the Font-colour is white as well,so its unreadable unless i hovered the space with the left mouse button holded.
What i want is to change the Colour of the font to black,so the posts in the forum can be visibles and readable.
if you want you can check some of the posts on www.aquariuspeople.com,if my description is not very well!
Thank you!
Kind Regards
Svilen Stoyanov
14 years 3 months ago #120119 by sozzled
Good to hear that you're not using the Example template. :)
Your problem is caused by your Joomla site template. Please read My Joomla template is making a mess of Kunena How do I change the colours of my template in Kunena? Do these articles help you?
14 years 2 months ago - 14 years 2 months ago #121942 by riseryn
htaccess: Missing | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : beez_20 | author: Angie Radtke | version: 2.5.0 | creationdate: 25 November 2009
Third-party components: CommunityBuilder 1.8 | UddeIm 2.7
I have the same problem but only for users using IE9.
The category select drop list background is white
The message textarea background is also white, all other parts are like defined in my joomla template
In kunena administration panel i have selected yes to the integration option with the joomla template.
This two items are the only one not respecting the colors within my joomla template.
How to give special instruction to IE to make correctly its job? ;)
No problems with Firefox(latest version)
In Chrome and Opera (latest version) only the drop list is affected
Last edit: 14 years 2 months ago by riseryn. Reason: typo
14 years 2 months ago #121951 by sozzled
G'day, riseryn, and welcome to Kunena.
I agree with you: Internet Explorer is really tricky to setup properly and you need to be extra careful when you write CSS.
What happens if you set
Kunena » Template Manager » Blue Eagle (default) » Blend with Joomla Template = No
Does your forum work then?
The problem you are having is caused by how you (or whoever modified the Beez20 template that you are using) wrote the CSS for your website (how you have defined the SELECT elements). If you used the standard Beez20 template then you would not be having these problems (see My Joomla site template makes a mess of Kunena
Time to create page: 0.321 seconds
