Question Templates and Colors
I found in the /components the Kunena template which let me switch between templates. So, I copied them to make 4 templates so I can change colors with ease. My Joomla 2.5 template uses very simple colors. I just need to make the your blue turn either green, red, or orange depending on which template to choose so I can make Kunena tabs colors change accordingly.
Can someone tell me which code in the template I need to change to change the tabs colors like; Main forum tab, who is online tab, statistics tab, etc.
Thank you.
The answer to your question depends on the Kunena template you are using (and also on the version of Kunena you are using). Depending on the Kunena template, there are settings in the Kunena Template Manager that you can change. Some other colour changes can easily be made by adding specific CSS rules to the end of your Joomla site template file (see How do I change the colours of my template in Kunena?
Does this help?
I have given you a general answer about "Templates and Colours" and I've asked you some questions to help us focus on the specific issues that you want to discuss. Your picture does not show me anything wrong, specifically. It looks just like any normal Kunena forum. Perhaps you could indicate on that image what you call "tab colours". What are these "tabs"? Are you talking about the Forum Header Background, perhaps?
I'm still guessing.
It would help to know what Kunena template you are using when you ask these questions. The answers depend on the Kunena template that you are using.
I have asked you to provide us with information about your Kunena template. From the sounds of things you have tried to create your own customised template. I do not know what Kunena template you have based your custom template - are we discussing the Example template or the Blue Eagle template?
I can easily answer the question if we are discussing the Blue Eagle template. If you are using a different template then the answer will be different. I have now asked you twice to give us specific information about what Kunena template you are using. You have not given us that specific information. Further answers from me, at this time, are based on educated guesswork. How about reading What information should I include when I ask for help (including how to post my configuration report)?
I think you need to go to Kunena Template Manager, edit Blue Eagle (default) template, change Forum Header Background to the colour that you want to use. However, from what you have written, I am only guessing and I am probably wrong.
