Kunena 6.4.13 Released
Question User List Navigation - UL displaying Vertically, not Horizonatally
14 years 6 months ago #116112 by GJSchaller
On my user list:
www.knightrealms.com/forum/userlist.html
The Navigation links at the bottom are displaying vertically, in a Unordered List, instead of Horizontally.
I've pulled my hair out looking for the CSS to control this, including comparing it to the Default template, but I can't seem to find it.
Can anyone point me to the right spot, and / or tell me what I'm missing in my code?
Thank you!
Geoffrey Schaller
Technical Officer
Knight Realms
14 years 6 months ago - 14 years 6 months ago #116114 by sozzled
Although this is not the standard Blue Eagle template, the fix is easy enough. Add the following lines to the end of your Joomla site template CSS file:
#Kunena ul li { display: inline; padding: 0 10px; }
These changes may have other effects on your forum but they will fix the issue that you've reported.
The following user(s) said Thank You: GJSchaller
14 years 6 months ago #116117 by CheechDogg
Hey sozzled I know this is our friend's GJSchaller post, but if I were to transfer all the contents of my kunena.default-min.css into my joomla site template any changes I made to it take effect?
I am just asking because I used the kunena.default-min.css to make changes to my template and I haven't upgraded because of those changes I made.
[img
Find me on Facebook.
14 years 6 months ago #116118 by GJSchaller
I wound up doing this, to minimize the effect:
#Kunena table.kblocktable ul li{
display: inline;
padding: 0 10px;
Geoffrey Schaller
Technical Officer
Knight Realms
14 years 6 months ago #116120 by CheechDogg
Did this work for you?
[img
14 years 6 months ago - 14 years 6 months ago #116121 by sozzled
CheechDogg: No problem with the minor hijack. We've had a similar discussion on this subject not that long ago: Override css changes when upgrading . I hope this helps. :)
GJSchaller: Yes, that's a better way to do it.
Time to create page: 0.259 seconds
