Kunena 7.0.8 Released
Question [SOLVED] Category Text Color on default template
14 years 7 months ago - 14 years 7 months ago #113758 by Rooster
I have been working on changing the color scheme much more dramatically than when the backend templete manager allows. I have been using firebug to try and pinpoint necessary colors, such as the Category background color.. But all that appears in firebug for the text field is this:
<h2> <span> <a rel="follow" title="" href="/CMS/index.php/forum/index/1-main-forum">Main Forum</a>
Maybe it's the wrong area, it's all that seems to be coming up though in firebug.. I don't know what to do with that information.. Doesn't seem to be pointing to a file/css/field that I can readily search for and set a font text color to!
Help?
Last edit: 14 years 7 months ago by Rooster.
14 years 7 months ago - 14 years 7 months ago #113759 by sozzled
Using Firebug isn't always the easiest thing to do but there's a little bit of help in the Wiki article Firebug .
What you should do look at the container for the <a rel=follow ...> HTML tag. You will find that the container for the category description is <div class="kheader"> and the style for that container is
#Kunena div.kblock > div.kheader, #Kunena .kblock div.kheader { background: none repeat scroll 0 0 #5388B4 !important; }
Therefore, if you want to change this blue colour to green, for example, you would add the following lines to your Joomla site template CSS file:
#Kunena div.kblock > div.kheader, #Kunena .kblock div.kheader { background: none repeat scroll 0 0 green !important; }
I hope that helps
Last edit: 14 years 7 months ago by sozzled.
14 years 7 months ago #113761 by Rooster
Really appreciate it - I'll give it a try and see what happens :)
One q for ya though about this - I did possibly you mention similar reply for another similar topic (it wasn't category text, but it was a text of some type). Why does that have to be done in the actual Joomla Template, and not in the Kunena's template? Is there a way to keep it exclusive to the Kunena template so that Joomla template use/selection has no effect on Kunena? (In other words so it doesn't matter what Joomla template is being run, or if I share a future template for Kunena without having to explain 'complicated' additional stuff that would have to be done). Just curious why it is the way it is.. :)
14 years 7 months ago #113763 by Rooster
Bah - I must've not gotten it nailed down.. I don't think it shows text color anywhere (in firebug at least). I made that change, but it changed the category header backgrounds (for all) to green, not the text (text is still a dark blue/gray) color. Any idea on the character text?
14 years 7 months ago #113766 by sozzled
Rooster wrote: I made that change, but it changed the category header backgrounds (for all) to green ...
Sorry, I thought that's what you wanted to do. My mistake.
You need to change the color attribute of the Kunena [HTML] <A> tag style. Can you do without any further help?
The following user(s) said Thank You: Rooster
14 years 7 months ago #113768 by Rooster
I hate to keep pestering, but I'd be telling a lie if I said 'yes'. That said, I will know after instructed, and suspect it might be quite beneficial down the road to altering other things :) Tnx for the time, really appreciate it!
Time to create page: 0.225 seconds
