Kunena 7.0.8 Released
Question [SOLVED] Category Text Color on default template
Help?
What you should do look at the container for the <a rel=follow ...> HTML tag. You will find that the container for the category description is <div class="kheader"> and the style for that container is
One q for ya though about this - I did possibly you mention similar reply for another similar topic (it wasn't category text, but it was a text of some type). Why does that have to be done in the actual Joomla Template, and not in the Kunena's template? Is there a way to keep it exclusive to the Kunena template so that Joomla template use/selection has no effect on Kunena? (In other words so it doesn't matter what Joomla template is being run, or if I share a future template for Kunena without having to explain 'complicated' additional stuff that would have to be done). Just curious why it is the way it is..
Sorry, I thought that's what you wanted to do. My mistake.Rooster wrote: I made that change, but it changed the category header backgrounds (for all) to green ...
You need to change the color attribute of the Kunena [HTML] <A> tag style. Can you do without any further help?
