Question Joomla site template gets in the way of Kunena
14 years 6 months ago #112593 by elcobra777
I upgraded Kunena sucessfully to the latest version (1.7.1).
Before the upgrade, the Kunena Forum integrated my website perfectly.
Unfortunately after havong upgraded to 1.7.1, the Kuena Forum doesn't integrate anymore my website.
My website: www.serieamania.net/footballmanagermania
Is there a way to make the integration possible?
Thanks for your help,
Andy
14 years 6 months ago #112597 by xillibit
Maybe you will find a template which match your needs here : www.kunena.org/ked/templates
The following user(s) said Thank You: elcobra777
14 years 6 months ago - 14 years 6 months ago #112602 by sozzled
G'day, elcobra777, and welcome to Kunena.
You have three choices:
(1) Do not show any modules that are displayed on the leftcolumn (the men, login, whoisonline, Football Manager 2012, SI). That's the easiest solution. The problem you have is caused by your Joomla site template.
(2) Add the following three lines to the end of your Joomla site template CSS file:
#Kunena { min-width: auto; }
(3) Find a different Joomla template that is wider and that doesn't float modules over the top of Joomla components like Kunena.
May I ask, what version of Kunena were you using before that integrated perfectly with your website?
14 years 6 months ago #112619 by elcobra777
Thank you very much for your help. B)
Following xillibit's advise I have uploaded a new forum template and it fits perfectly with my joomla template. Thanks again.
To answer sozzled's question, I don't remember the version of Kunena that I was using before, but it was an older version, less developed than the present one.
Andy
