Question [RESOLVED] "Funny" icons/buttonsets
- joopyjoops
- Junior Member
14 years 10 months ago - 14 years 10 months ago #112328
by joopyjoops
[RESOLVED] "Funny" icons/buttonsets was created by joopyjoops
Have just installed KUnena 1.7.1 and all looks okay so far, except the icons for things like favourites etc...
mainlymanly.com.au/forum/life-on-the-nor...6-manly-market-place
Also, the width of the main index and recent topics pages is slightly less, which means that text is getting chopped off on the right hand side:
mainlymanly.com.au/forum/recent
Any idea what is going on?
Last edit: 14 years 10 months ago by sozzled. Reason: Change topic icon and status
14 years 10 months ago #112333
Replied by sozzled on topic Re: Funny icons?
Basically, the problems that you are having (the forum width being chopped off) are controlled by the Joomla template that you've chosen.
The buttonset issues are controlled by the template settings. It would help to know what Kunena template you are using. Our advice is to start with the basics - a template that works (namely the Blue Eagle template) and make minimum changes so that you can be assured that (at least) that one works properly. I hope this helps.
The following user(s) said Thank You: joopyjoops
- joopyjoops
- Junior Member
14 years 10 months ago #112337
by joopyjoops
Replied by joopyjoops on topic Re: Funny icons?
Thanks for getting back to me so quickly.
Yep, i'm using the Blue Eagle (Default) template. Have just changed the 'Button Set' to default (was whitebird), so all fixed. Thanks for that!
Do you know how i can fix the problem of it being a few pixels short on the RHS?
e.g.:
mainlymanly.com.au/forum/life-on-the-nor...summer-holidays#2264
e.g.:
14 years 10 months ago - 14 years 10 months ago #112351
That's sort of a different question that's unrelated to the buttonsets matter. See your PM.joopyjoops wrote: Do you know how i can fix the problem of it being a few pixels short on the RHS ...
14 years 10 months ago #112442
Replied by sozzled on topic Re: [RESOLVED] "Funny" icons/buttonsets
Resolved the forum width issue by removing the login module from the right side of the page.
Time to create page: 0.211 seconds
