Question Access to 1.7.1 default css?
15 years 8 hours ago #112162 by IOWPC
Besides downloading the default .css file is there any way to access it?
I'm reasonably experienced with css files and want to adjust the default template to my own colours.
Reapplying these changes at updates is not an issue.
15 years 7 hours ago #112165 by sozzled
G'day, IOWPC, and welcome to Kunena.
If you are reasonably experienced with CSS and you would like to change the colours, I suggest that you look at the FAQs (see the menu item above this forum) to find more information about How do I change the colours of my template in Kunena?
The following user(s) said Thank You: IOWPC
15 years 7 hours ago #112174 by IOWPC
Thank you Sozz.
Although I had looked at the link before putting my Q up I hadn't considered making my own template, however looking at the instructions it certainly looks within my capability and is what I'll do. I'll make it available when finished.
Thank you for taking the time to reply.
Regards.
IOWPC.
15 years 7 hours ago #112175 by sozzled
NP ... and good luck! :)
