Question Re: Restoring Kunena Menu SOLVED
15 years 2 months ago - 15 years 1 month ago #107291 by DJ
I'm perplexed here; I am a novice and am very confused. Went to FAQ and found this:
How do I restore my Kunena menu?[2]
The Kunena menu is a set of tabs that appears across the top of the forum pages. In some cases, this menu does not appear for a variety of causes.
A simple remedy for the problem is to use the trash-burn-build technique:
Trash all existing menus and menu items that relate to your Kunena forum
Ensure that you do not have a folder named /forum on your site.
Empty the menu trash.
Use the Create Menu feature in the Kunena control panel to restore your Kunena menu.
Make sure that you publish a link in your menu that calls the Kunena forum. Use the Alias Menu type to define that link (see Customised menus for more information)
Ensure that you have published a menu module for the kunenamenu template position.
I do not understand where we are publishing a link; I could find not alias menu type. I followed the link to Customised menus, but directions called for a menu type "alias" and there is none listed for Joomla 1.7.
Here is my configuration:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : js_vintage_001 | author: Casey Lee | version: 1.1 | creationdate: 12/20/07
Last edit: 15 years 1 month ago by DJ.
15 years 2 months ago #107385 by xillibit
Replied by xillibit on topic Re: Restoring Kunena Menu
Look in Joomla! menu manager, you have alias for each menu items. For each menu item, the alias need to be unique
15 years 2 months ago - 15 years 1 month ago #107394 by DJ
Replied by DJ on topic Re: Restoring Kunena Menu
I just checked again and they do all appear to have different alias. I'm one step closer to getting this working--last problem is to get the Kunena Menu to appear. I followed the directions in wiki, but now I cannot seem to get it to show. I have the Kunena module appearing but no subcategories to be able to click to access the forum? I'm attaching 2 screen shots in the event they help. I suspect it is something simple that I am just overlooking.
15 years 1 month ago #108641 by DJ
Replied by DJ on topic Re: Restoring Kunena Menu SOLVED
I'm not sure what I did but believe it had to do with linking. Whatever it was, I now have it working. This matter is SOLVED.
