Question Conflicts with browsers/site template
15 years 4 months ago #100511 by universalckcs
My site template is very dark with white text and I am using the Blue Eagle forum template with blending. My subscribers who use IE are unable to see what they are posting because the subject and text areas are white and the text is white. I've tested in Firefox and the text area matches the site templates but the icons for submit, etc are not clearly visible (just the text but no outline box). I've attached an image to show how it looks in IE. I am hoping that someone can give me a quick, easy answer to fix the problems. Changing the entire site template for the forum is not really an option. Thanks.
15 years 4 months ago #100537 by sozzled
The quick, easy answer to your question is that web design is not something that can be quickly, easily answered.
General observation about Internet Explorer: IE7 is different to IE8; IE8 is different to IE9 and each generation of Internet Explorer is different to everyone else's interpretation of CSS.
The super-quick, easy answer to your question: see How do I change the colours of my template in Kunena? .
The super-duper-quick, easiest answer to your question: employ a professional web designer to undertake the work for you.
15 years 4 months ago #100542 by universalckcs
Thanks. Figured out the problem when I tried another forum and had the same issue. It will work with compatibility mode in IE8.
