Important attachment issue
- csrountree
www.PureCrossTraining.com --> its under the Training Tab
I also tried it with the default (blue) template and it does not work. I am not thinking it is a template issue.
- csrountree
I'm sorry, what do you mean? See www.purecrosstraining.com/index.php?opti...iew=search&Itemid=92csrountree wrote: It wont even allow for the search box to open up.
Are you saying that you are having problems with the Aphotic II template? Have you written to the author of that template?
Is there something wrong with this topic (that has an attachment): www.purecrosstraining.com/index.php?opti...id=13&id=4&Itemid=83 I can see the attachment (when I click the link). I'm not sure I understand your problem.
- csrountree
Are you claiming that the Kunena search feature does not work? I clicked the Search tab and it worked for me.
Are you claiming that you cannot attach images to your forum posts? I found a forum message that has an attached image. What seems to be the problem?
What seems to be peculiar with your Joomla template? Can you show us (with picures, perhaps) the steps that you took to reproduce the problems that you have reported and that you would like our help with. Can we reproduce those symptoms here, for example?
