Important attachment issue
15 years 5 months ago - 15 years 5 months ago #97050 by csrountree
attachment issue was created by csrountree
please check out the forum on my site. it is not wanting to allow any attachments (images) when you attempt to add an image on a or used post. It wont even allow for the search box to open up.
www.PureCrossTraining.com --> its under the Training Tab
I also tried it with the default (blue) template and it does not work. I am not thinking it is a template issue.
Last edit: 15 years 5 months ago by csrountree.
15 years 5 months ago #97094 by sozzled
Replied by sozzled on topic Re: attachment issue
"Only community members can participate in forum threads. You must register or log in to contribute."
15 years 5 months ago #97096 by csrountree
Replied by csrountree on topic Re: attachment issue
ok, check it now. Sorry about that.
15 years 5 months ago - 15 years 5 months ago #97099 by sozzled
csrountree wrote: It wont even allow for the search box to open up.
I'm sorry, what do you mean? See www.purecrosstraining.com/index.php?opti...iew=search&Itemid=92
Are you saying that you are having problems with the Aphotic II template? Have you written to the author of that template?
Is there something wrong with this topic (that has an attachment): www.purecrosstraining.com/index.php?opti...id=13&id=4&Itemid=83 I can see the attachment (when I click the link). I'm not sure I understand your problem.
Last edit: 15 years 5 months ago by sozzled.
15 years 5 months ago #97100 by csrountree
No, its not the forum template, it is the Joomla template. I tested it on beez and it worked fine. I was just seeing if there were any suggestions, or anyone ideas as to what the conflict is.
15 years 5 months ago #97102 by sozzled
I'm sorry, but I don't understand the issue or issues.
Are you claiming that the Kunena search feature does not work? I clicked the Search tab and it worked for me.
Are you claiming that you cannot attach images to your forum posts? I found a forum message that has an attached image. What seems to be the problem?
What seems to be peculiar with your Joomla template? Can you show us (with picures, perhaps) the steps that you took to reproduce the problems that you have reported and that you would like our help with. Can we reproduce those symptoms here, for example?
