Question Template alignment problems.
15 years 5 months ago - 15 years 5 months ago #96819 by Jfrm
Hi!
I'm using Joomla 1.63 with last Kunema version.
In Joomla I have made a custom template and in Kunena I'm using default one.
All is working perfectly but two missalign I couldn't identify (Private messages and page index):
I have made lot of changes both to my joomla and kunena templates (Kunena already in debug mode), but don't find a way to affect those areas or solve this problem.
I will apreciate any advice. Thanks in advance.
Last edit: 15 years 5 months ago by Jfrm.
15 years 5 months ago #96916 by 9themestore
Hi Jfrm,
I think, you should post the live site link. :)
15 years 5 months ago - 15 years 5 months ago #96918 by Jfrm
Thanks for your reply, but there is not a live site at the moment. I'm preparing in local.
Anyway I have finally found solution changing: components\com_kunena\template\default\css\kunena.forum.css
#Kunena .kpagination li{
border:0;
margin:0;
padding:0;
font-size: .667em;
list-style-type:none;
line-height: .667em;
display:inline; /* Original: display:inline-block;*/
#Kunena td.kprofileboxcnt ul li {
display: inline; /* Original: display: block;*/
background: 0 none;
With this changes all is ok. Thanks
15 years 5 months ago #96928 by 9themestore
Replace your code section by the following css section.
#Kunena .kpagination, #Kunena .kpagination ul { overflow: hidden; } #Kunena .kpagination li{ border:0; margin:0; padding:0; font-size: .667em; list-style-type:none; line-height: .667em; display:block; /* Original: display:inline-block;*/ float: left; /* Add new */ } #Kunena td.kprofileboxcnt ul { overflow: hidden; } #Kunena td.kprofileboxcnt ul li { list-style-type:none; display: block; /* Original: display: block;*/ float: left; /* Add new */ background: 0 none; }
Tell me if don't work. :)
The following user(s) said Thank You: Jfrm, web3mantra
