Important Upgrade from 1.6.0 to 1,6.4 - CSS issues
14 years 11 months ago #95582 by iLucato
Yup,one is around line 31 the other online 19, but from what file? If you check on firebug, you don't get to see from what .css file it is coming from, do you? it shows just a huge link like this:
www.esferadobem.com.br/index.php?option=...nc=latest&Itemid=112
I'm not getting to find it. The #ktop "instance*" should be only one from my own template, and I don't know why it is showing this !important you showed as a doubled. I wonder, where it is coming from. I have already renamed the original default CSS folder (../components/com_kunena/template/default/css-old) just to keep mine and didn't solve, it keeps blue as you saw. Weird.
*) I don't know the right name to call it. ;0)
14 years 11 months ago - 14 years 11 months ago #95613 by Matias
Also check if your colors can be changed from the template itself..
I mean all Kunena 1.6 templates have a few parameters which you can set from the backend.
Last edit: 14 years 11 months ago by Matias.
14 years 11 months ago #95625 by iLucato
Matias wrote: Also check if your colors can be changed from the template itself..
I've done that already and #Ktop isn't controled from there and into my CSS folder template files as:
ie7-fix-min.css
ie7-fix.css
kunena.forum-min.css
kunena.forum.css
there is no such color into these files at #ktop or at other place.
Time to create page: 0.244 seconds
