Question Forum link
15 years 6 months ago #95473 by Tweezer
Forum link was created by Tweezer
I have installed kunena forum to my site and have it working great. The only problem that the forums show up inside the website template with the website menus on the side. How do I set the link to the forums so that it would not have the website menus down the side?
15 years 6 months ago - 15 years 6 months ago #95545 by sozzled
Replied by sozzled on topic Re: Forum link
You asked your question in the K 1.5 Common Questions category. Can you please confirm exactly what version of Kunena you have installed? Please also see K 1.5.x Support: Please read this first. This might help. Thank you.
Last edit: 15 years 6 months ago by sozzled.
15 years 6 months ago #95599 by Tweezer
Replied by Tweezer on topic Re: Forum link
Thanks for the info and sry for the wrongful post. I am using Kunena v 1.6 and Joomla 1.5. I miss posted as I got the versions mixed up. My apologizes.
15 years 6 months ago #95651 by sozzled
Would you like to post your K 1.6 configuration report and then we might be able to see the problem? Thank you.
15 years 6 months ago #95687 by Tweezer
htaccess: Exists | PHP environment: Max execution time: 20 seconds | Max execution memory: 128M | Max file upload: 10M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.3)
15 years 6 months ago - 15 years 6 months ago #95696 by sozzled
K 1.6.0 is not supported. Please use K 1.6.4. It is important that you read K 1.6 Upgrade Guide first.
Time to create page: 0.154 seconds
