Important template messing up my forum
15 years 7 months ago #91299 by werner
Hi Peeps.
I got a new template and am continuing building my website. I have been working on it for quite some time and will only launch in 6 months. My template is quite good with automatically creating buttons like read more ect. Unfortunately it is messing up the forum section on my page. Where ever there is buttons on the forum it looks like the image attached. Any advice on this?
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 24M | Max file upload: 10M
Joomla default template details : dominator | author: MightyTemplate | version: 1.2 | creationdate: March 2010
Modules: Kunena Latest: Disabled or not installed | Kunena Stats: Disabled or not installed | Kunena Login: Enabled (Version : 1.6.2)
15 years 7 months ago #91348 by sozzled
We cannot access your site/forum. The only advice we can suggest in this case is to use a web developers tool like Firebug for Firefox to analyse what is causing the CSS rule conflict. Good luck.
Off-topic: it would be a good idea to implement Joomla SEO and to upgrade to J! 1.5.23.
15 years 7 months ago #91404 by werner
Thank you for responding.
I do not have the tool and won’t understand what I see as I am new to joomla and web design.
I created a temp login for you to see the site.
Please have a look if you get some time.
Username: adonai
Password: hillsong
15 years 7 months ago #91439 by sozzled
One of the first lessons in good web design is to keep things simple. I can't find (on your website) where to login. So if you can't help us to find out what's going on with your site you may want to try using a simpler site template that doesn't cause the issues that you are having.
15 years 7 months ago #91507 by werner
Thank you for the encouragement. I am new to joomla and design so for what I have done so far I am quite proud of myself.
I am a bit surprised by the response as on top of each page there is a login form as shown in the pic attached. I have tested this on Mac, IE, Chrome and fire fox. So I do not know why you cannot see it. Buy I will obviously have to look into that. No idea where I will start but hey, at the moment I need my forum sorted.
15 years 7 months ago - 15 years 7 months ago #91512 by werner
also you dont need to login to see the forum, yet when you do ligin and have more options it gives me the problem i need to solve
Last edit: 15 years 7 months ago by werner .
Time to create page: 0.151 seconds
