Question Highlight moderator messages
15 years 10 months ago #82552 by uastasi
Hello everybody,
I'd like to highlight every message posted by moderator with a css class different from the default one.
I've seen that ./funcs/views.php renders a <table class="kmsg"> for every message posted. Is there a way to check if who writes is a moderator and then applying a custom class?
Thank you in advance
15 years 10 months ago - 15 years 10 months ago #82802 by uastasi
I've slightly modified view.php to obtain a raw implementation of the feature.
I've added these lines in display() function:
// Highlight moderator messages if ($this->highlight($this->id, $this->userid )){ $this->class = 'class="kmsg-moderator"'; } else { $this->class = 'class="kmsg"'; }
Then I've added a function called highlight() in the same class:
/** * Highlight a message if its author is a moderator. * * @param mixed $messageId The message. * @param mixed $userId The message author. * @return boolean $isModerator 0 = False, 1 = True */ function highlight($messageId, $userId ){ $isModerator = false; //Check that the author is not anonymous if ($userId != 0){ $query = "SELECT a.userid, moderator FROM #__kunena_users a, #__kunena_messages b WHERE a.userid = b.userid and b.id = {$messageId}"; $this->db->setQuery($query); $row = $this->db->loadObject(); if ($row->moderator == 0) $isModerator = false; else if ($row->moderator == 1) $isModerator = true; } return $isModerator; }
At the end I've added a custom class called kmsg-moderator into the css file.
Feedback and improvements are welcome.
Last edit: 15 years 10 months ago by uastasi.
