Question "icon_unanswered"
15 years 10 months ago #82071 by robgul
"icon_unanswered" was created by robgul
Is there a way to suppress the display of the telephone icon that seems to signify that a post has no replies?
I've searched this forum and all the component settings - can't fin an answer. I don't really want to resort to "tricking" it with a plain white square to replace the phone icon image
Other than that - have to say the whole thing is a great improvement since I tried it about 18 months ago. Excellent
Rob
15 years 10 months ago #82109 by sozzled
Replied by sozzled on topic Re: "icon_unanswered"
robgul wrote: Is there a way to suppress the display of the telephone icon that seems to signify that a post has no replies?
I'm sorry. I haven't seen this "telephone icon" anywhere. Where do you see this thing? Is this a question for the Kunena project? :S
15 years 10 months ago #82113 by robgul
Replied by robgul on topic Re: "icon_unanswered"
Hi - if you go to www.cycle-endtoend.org.uk/index.php?opti...d=1000010&Itemid=183 you should see it! I've also attached a screen-grab.
Rob
15 years 10 months ago - 15 years 10 months ago #82133 by sozzled
I'm sorry, that's not something that I'm familiar with. Can you see this "telephone icon" on a standard installation of Kunena, like here www.kunena.org (for example)? Looks like this is some customised template to me. Where did you get the template from? You probably need to talk the matter over with whoever designed your Kunena template, I think.
To me, even though I haven't seen this feature before, the idea actually looks quite attractive.
Last edit: 15 years 10 months ago by sozzled.
15 years 10 months ago #82176 by robgul
No - the Kunene set-up is straight out of the box with the default template, no changes have been made other than through all the config/setup setings - the site template is a freebie from Joomlashack.
The image file that is showing is called icon_unanswered.png .... but I guess that you can see that.
It would appear to display when the post has had no additional posts - i.e. is "unanswered" - whether it changes when a post has been made I don't know (my forum is new and in test)
Rob
15 years 10 months ago #82184 by @quila
Replied by @quila on topic Re: "icon_unanswered"
Hi Rob,
look in the configuration of Kunena (Frontend tab) and change option "Selectable Topic Icons" to YES. Then in your forum will show normal icons.
If you set this option to NO you users will not have option to select icon for topic when create a new topic and Kunena show automatic icons you seen now.
Regards
