Question Little bug in layout
Some parts of Kunena (like the buttons) are inside/outsite of layout that I use in Joomla, as you can understand better by seeing the attached photo. does anyone know how can I fix this?
Thanks a lot!
If you have the skill, the patience and the perseverance, you can fix these issues yourself. You showed us a picture of your website and I can see the problem.
Let me give you an example. Suppose I have a problem with my car - my car won't start, for instance. I can show you a picture of my car but will that help you identify what is causing my car to not start? Have you checked the fuel, the electrical system, the starter motor?
The same is true, too, when people show us a picture of their website and they say "I have a problem with it." Quite often, the only advice we can give them is very general advice. Have you tried to use a web page analysis tool (like Firebug ) to identify the cause of why your site template is incompatible with Kunena?
Everyone's website is as unique as every person on the planet is unique. It's your website and the issues that you have are because of the decisions that you have taken. I'm trying to help you, I really am, but you also need to know that you need to help yourself, too. So, when I advised you to try using a standard Joomla template I wasn't telling you how to run your website. I was trying to help you see that the problem was probably caused by the choice of site template that you have made rather than Kunena itself. So, would you like to try my suggestion first and, if that works, then we can discuss whether or not your site template is the issue behind the problem that you're having?
Thanks for help, sozzled!
As you can see,you have identified the cause of the issue and you now have a range of different options that are available to you.vien wrote: ... the error is only with this template and some more, which has a relatively small space to the forum and contents.
It may be possible to patch up things with the template that you chose, or maybe it's not really worth the cost of trying to make things work.
I have a saying: "Nothing is impossible. Everything has a cost." You can achieve anything you want, if you are prepared to pay a price. The cost may not just be dollars and cents; it might be take time or you might need to acquire certain skills or you might need to employ someone else to take care of things that you don't have the time. There are no correct choices; there are only your choices and those that seem right for you in the circumstances.
By the way, there are thousands of Joomla templates that work spectacularly well with Kunena. It might be worth taking the time to browse around this site to see some of the designs that others are using.
