Question Module under every Post
15 years 10 months ago #79110 by SyNuge
I thought this would be easy but I'm scratching my head over it.
All I want to do is post two modules under every post (/message) on a page. If I only had one message per page the kunena_msg_1 position would work fine but I can't find a way to make this dynamically happen for every message.
On other posts I have seen mention of hacking the threadactions php file but this appears to add the modules to the top of the page as well as under each post and this messes up the layout.
Any ideas gratefully received.
Thanks,
Simon
15 years 10 months ago #79125 by SyNuge
Replied by SyNuge on topic Re: Module under every Post
OK - I worked around this by pasting the Twitter and Facebook code directly into the message.actions.php file.
Not brilliant as it won't survive an upgrade but at least it gets me going.
15 years 10 months ago - 15 years 10 months ago #79840 by yaksushi
I can't believe there isn't a plugin for this.... Could you explain how and where you did your hack? I've put a facebook like module into my K2 template by using
<?php jimport('joomla.application.module.helper'); $mods = JModuleHelper::getModules('module_name'); echo JModuleHelper::renderModule($mods[0]); ?>
before, are you doing something similar?
Last edit: 15 years 10 months ago by yaksushi.
15 years 10 months ago #79864 by SyNuge
In the end I modified both message.actions.php (to add the Twitter link) and message.thankyou.php (to add the Facebook link). My thinking was that the Facebook like should show in the same circumstances as the thank you (i.e. you shouldn't be able to "like" your own post).
So my modified code was as follows:
message.actions.php
<div class="kmessage-buttons-row"> <?php if (empty( $this->message_closed )) : ?> <?php echo $this->message_quickreply; ?> <?php echo $this->message_reply; ?> <?php echo $this->message_quote; ?> <?php echo $this->message_edit; ?> <?php echo $this->message_moderate; ?> <?php echo $this->message_move; ?> <?php echo $this->message_merge; ?> <?php echo $this->message_split; ?> <?php echo $this->message_delete; ?> <?php echo $this->message_permdelete; ?> <?php echo $this->message_undelete; ?> <?php echo $this->message_publish; ?> <?php echo '<br><a href="http://twitter.com/share" class="twitter-share-button" data-count="horizontal" data-via="pQ_dotcom">Tweet</a><script type="text/javascript" src="http://platform.twitter.com/widgets.js"></script>' ?> <?php else : ?> <?php echo $this->message_closed; ?> <?php endif ?> </div>
<div class="kpost-thankyou"> <?php echo $this->message_thankyou; ?> <?php echo '<fb:like href="http://www.psychicquesting.com/index.php?option=com_kunena&func=view&catid=1&id=562&limit=6&limitstart=6&Itemid=31" layout="standard" show_faces="true" width="450" action="like" font="arial" colorscheme="light"></fb:like>' ?> </div>
As you can see from the second file, I am not using "raw" facebook widget code but rather a module called JFBConnect from SourceCoast as this handles users logging into to my site (and Kunena) with their Facebook credentials.
Hope that helps,
Simon
The following user(s) said Thank You: yaksushi
15 years 10 months ago #79944 by yaksushi
I use k2 and I like how they do their "Tweet it to your followers" I tried just pulling out of k2 what I thought was the right chunk of code but it doesn't work. It displays correctly but when I click on the tweet this link it takes me back to my home page... :(
I tried adding this
<span class="itemTwitterLink"> <a title="<?php echo JText::_('Like this? Tweet it to your followers!'); ?>" href="<?php echo $this->item->twitterURL; ?>" target="_blank"> <?php echo JText::_('Like this? Tweet it to your followers!'); ?> </a> </span
It's not processing the link correctly....
15 years 10 months ago #79971 by SyNuge
The standard Twitter widget is not bad. Is it worth testing with that (see my code above) and seeing if you can at least get that working?
