Question Index page font sizes too small
15 years 11 months ago #78717 by bigmike0601
www.OceanCity2do.com is my test site running Joomla 1.5.22 and K1.6.1
How can I make the font sizes the same as this site?
Thanks,
Mike
15 years 11 months ago #78791 by sozzled
G'day, Mike. As you know, the font sizes (styles, colours, etc.) used in Kunena on your website are very much affected by whatever is defined in your Joomla site template. This is actually very easy to see if you use a web design tool like Firebug for Firefox. If you don't use Firefox - for example, you might be using Google Chrome - there may be a design tool already built into your browser to let you see what's going on "behind the scenes".
Therefore, when we're asked these general kinds of "how do I make the font size [on my website] the same size as the fonts used here [at www.kunena.com ]" the answer depends a lot on how you have already defined the font size on your website. There is no prescriptive answer to this question simply because everyone's website is different. Some people like really small fonts and some people like really large fonts. These fonts sizes are defined by your site template although you can, if you want to, define them in your Kunena template to be used specifically for Kunena!
The problem that I have, in trying to help you find the answer to your question, is to understand which particular font size is "wrong" in your case. Is the font too small or too large? I looked at your website www.OceanCity2do.com and the sizes of the fonts you've used look OK to me. Perhaps you can show us, with a picture, specifically which fonts are too small or too large and what you would like them to look like. :)
15 years 11 months ago - 15 years 11 months ago #78840 by bigmike0601
I have attached screen shots of live site running K1.5 and test site running K1.6
As you can see, the first screen shot uses space more wisely with larger fonts than does the second screen shot. The use of avatars takes up more space across the whole row, but the font should be increased to occupy this empty space.
Mike
Last edit: 15 years 11 months ago by bigmike0601.
15 years 11 months ago #78849 by sozzled
So, what do you want to do? Do you want not to show avatar images (that's just a configuration setting, if you want to know the answer, by the way)? Do you know what specific size of font you need to achieve the desired result? I'm sorry, but my eyesight is not very good and I could not easily see the difference between the two images - you know those games, ("Spot the 10 differences")? I'm not very good playing those kinds of games. Perhaps if you marked on the image of what you want your site to look like then I might be better able to answer your question.
I spent 10 minutes switching back and forth between those two images and, apart from the presence of the avatar image on one of them, I couldn't tell them apart. Maybe someone else can see the problem. Sorry. :(
