Question hide text issue
15 years 11 months ago #76876 by Troneas
hide text issue was created by Troneas
hello.
the hide text feature is creating a white background / box on my text... and my text is white.
so in order for registered users to read the hidden text, they need to highlight it with their mouse.
the message displayed on guests is fine, though.
thnx for any advice on how to get this fixed.
Joomla default template details : game_crusade | author: Shape5.com | version: 1.0 | creationdate: December 2009
Third-party components: AlphaUserPoints: Installed (Version : 1.5.12) | CommunityBuilder: Installed (Version : 1.2.2) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.0-RC2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.6.0-RC3) | Kunena Stats: Disabled or not installed | Kunena Login: Disabled or not installed
15 years 11 months ago #77011 by xillibit
Replied by xillibit on topic Re: hide text issue
Can-i see it on your site ?
15 years 11 months ago - 15 years 11 months ago #77199 by Troneas
Replied by Troneas on topic Re: hide text issue
xillibit wrote: Hello,
sure, but you'll need to register to see how it shows to registered users.
want me to create a sample first?
thnx.
Last edit: 15 years 11 months ago by Troneas.
15 years 11 months ago #77361 by xillibit
if you want give me just a test account
15 years 11 months ago #77382 by Troneas
ive sent you a test account via pm.
here's a link to the sample text:
www.mmofringe.com/index.php?option=com_k...2499&Itemid=213#2499
thnx!
15 years 11 months ago #77394 by xillibit
Set debug mode on on in kunena configuration panel, in the file kunena.forum.css you will find this :
#Kunena div.kmsgtext-hide { background: none repeat scroll 0 0 #FFFFCC; }
just delete the #FFFFCC or use an another color
