Question Messed up, argh..
15 years 11 months ago #76524 by Xsandor
Messed up, argh.. was created by Xsandor
Earlier this night I thought it was a good idea to remove my profile box. I believe I removed the following code from kunena.php
//BEGIN: PROFILEBOX
if (file_exists(KUNENA_ABSTMPLTPATH . '/plugin/profilebox/profilebox.php')) {
include (KUNENA_ABSTMPLTPATH . '/plugin/profilebox/profilebox.php');
else {
include (KUNENA_PATH_TEMPLATE_DEFAULT .DS. 'plugin/profilebox/profilebox.php');
//FINISH: PROFILEBOX
I have now decided to restore my profile box, though I managed to not take a backup of my kunena.php file.
Any1 who can check their kunena.php file for the location of this code so I know where to put it :P
Version 1.6.1 btw
15 years 11 months ago #76526 by sozzled
It would be much more helpful to us if you explained what you specific problem was and if you chose a more meaningful subject to highlight those issues.
From what you have written, you have changed something. From a support perspective, our advice is to restore your site to the situation it was in before you changed "something" (from a backup, for example) or reinstall the version that you are now using.
