Question Tweaking Skinner: possible?
- Mr Livered
- Senior Member
However, due to the nature of the Joomla template, it produces a rather intense look. Is it possible to enable the skinner option, but override one or two things (for example, background colours)?
Thank you
To do so, turn kunena into debug mode and use e.g. firebug to identify which components and settings to change.
- Mr Livered
- Senior Member
Yes we could have gone heavy on java script to make it work, and some things would look even better with that. BUT - keeping it css only makes it simple for anyone to adapt.
IN the end our decision was for simplicity and performance.
- Mr Livered
- Senior Member
Nevertheless I have to admit that I am still struggling to decipher the relationship between the Skinner, Blue Eagle, and Joomla template css files :blush:fxstein wrote: keeping it css only makes it simple for anyone to adapt.
Say I wish to make a simple change such as modifying the font sizes - with Skinner enabled, what should be edited to achieve this, preferably within Kunena only?
Thanks.
The relationship is this: There is the Blue Eagle (default) template; this template has the option "Blend with Joomla template"
People should not change the Blue Eagle (default) template. If you change the template then all your changes will be lost when you upgrade to the next version of Kunena. The recommended approach is, if you have particular customisations in mind, to create your own template and install your own template using the Kunena Template Manager. There is a "skeleton" example template provided for that purpose but you should not edit the example template in situ either (because any changes you make will be lost when you upgrade)! People should think of the Example template is a template for a template; people should think of the Example template as a model that you can take, adapt, make a few changes, and save as the basis of a new template for your Kunena forum ... something that will be durable and long-lasting and that won't be over-written whenever you upgrade.
I hope this helps to explain things a bit better.
