Idea Forum Header- Change from blue?
Something is wrong in your install. The template parameters should work just fine. We are suing them on various test sites to change the colors.
Are you using them with or without Auto Blend option?
Can you post a screen shot of the template setting?
- crystalm28
- Junior Member
I am attaching two files.
1. Blue Eagle Template print screens & CSS file (after manually editing)
2. Example Template print screens & css file (after manually editing)
Here is what I want to accomplish.
1. Change the blue headings to the same grey color used in the menu
2. Change the folder image to the same grey color used in the menu
3. Change the blue font to black
Thank you, Thank you!!!!!!!!!!!!!!!!!!
www.kunena.org/forum/170-k-16-templates-...y-kunena-16-template
If that works, your installation is OK and your problem is solved (using a different method). If not, you've altered your default template (or other files) in a way that's causing a problem.
- crystalm28
- Junior Member
Can you tell me what section in your CSS code allows you to edit the topic headers?
Can you tell me how to change the blue file folders?
Thank you again!!!
Crystal
At a guess, I would saycrystalm28 wrote: Can you tell me what section in your CSS code allows you to edit the topic headers?
#Kunena div.kheader {
background:none repeat scroll 0 0 #5388B4;
You can confirm this with Firebug .
You need to use an image editor to paint new images. Something like Inkscape , for example.crystalm28 wrote: ... the picture of the envelope also stayed blue ... Can you tell me how to change the blue file folders?
Replace the color with the one you want.
