Question Problem: All Topic Icons have a border
16 years 1 month ago - 16 years 1 month ago #67878 by whitevitz
I am using Kunena 1.6 and the topic icons have a border to them. Please see the attached file.
I searched for topicicon in com_kunena files so I can add a border="0" to the img src for topic icon, but I cannot find it anywhere.
Closest I got to is this line in/com_kunena/template/default/threads/flat.php
<td class="kcol-mid kcol-ktopicicon"> <?php echo CKunenaLink::GetThreadPageLink ( 'view', intval($leaf->catid), intval($leaf->id), $unreadPage, intval($this->config->messages_per_page), CKunenaTools::topicIcon($leaf), intval($leaf->lastread) ) ?> </td>
If I delete the line above, the topicicon will disappear from the forum...but how do I add a img border="0" to it?
Thank you in advance
Last edit: 16 years 1 month ago by whitevitz.
16 years 1 month ago - 16 years 1 month ago #67882 by sozzled
The issue is probably caused by your site template CSS. You can use Firebug for Firefox to confirm if (as I suspect) all your image links are set to use a border-style like you've shown in your example.
There should be no need at all to modify any Kunena source code to fix this issue. As you can see at www.kunena.com , the issue isn't here, is it?
Last edit: 16 years 1 month ago by sozzled.
The following user(s) said Thank You: whitevitz
16 years 1 month ago #67883 by whitevitz
Thank you for your reply. I know the issue is caused by joomla.css
as I have remove the img { border: 0;} as I would like to have borders for other images for another components.
I am wondering where can I find this code in kunena files.
<img alt="emo" src="topicicon path">
as I would like to add a border="0" to it.
Thx
16 years 1 month ago #67894 by sozzled
Try adding
kcol-mid kcol-ktopicicon {
border: 0;
to your joomla.css
16 years 1 month ago #67904 by whitevitz
Thank you.. but unfortunately it didn't work. :(
16 years 1 month ago #67931 by sozzled
Well, maybe if you gave is the URL of your website, we might able to tell you what specific line of CSS code you need to change?
