Question Gavick Mega Menu Doesn't Work with Some 1.6 Templates.
16 years 1 month ago #65917 by aaronblrt1
I'm using the Gavick mystore template on my joomla site and using the MegaMenu. I downloaded the EuroTemplate Blue and I have the default Blue Eagle Template. Both templates cause the MegaMenu to stop working on the Kunena pages.
I have found one template to not affect this and that is joomlana-blue
Does anybody know what the problem is and why it could be breaking my MegaMenu and why this template isn't?
16 years 1 month ago #65921 by fxstein
Yes - it is a known fact that the Gavick Mega Menu is not compatible with mootools 1.2.x it is based on the outdated 1.1 and has not been updated by its authors.
One of our german members has come up with a potential partial fix for that: www.kunena.com/forum/36-german/65831-loe...plates-und-kunena-16
Ultimately Gavik will have to update their Mega Menu code to run on the latest Joomla versions, unfortunately they have not maken that happen.
You see this with Kunena because we dynamically enable the Mootools Upgrade Plugin for Kunena pages, that has been shipping with Joomla since 1.5.19 and is a compatibility layer for outdated templates and menu modules to run on the new libraries. Joomla 1.6 wont have that compatibility layer but will only support mootools 1.2.x+
There are other template clubs out there like RocketTheme that have updated the last 2+ years of all of their template to support that latest mootools 1.2.4 - they will most likely again be the ones who will lead with Joomla 1.6 work - as pretty much all of their javascript conversion is already done.
16 years 1 month ago #65922 by aaronblrt1
Can someone translate what is being said in the german post. I was trying to make sense of it but can't...
I've been using Gavick templates for a while because there layouts are mostly the same so if you switch templates, there isn't really any work to be done.
16 years 1 month ago #65949 by aaronblrt1
Why can't there be 2 version of Kunena 1.6? One for new & one for old mootools?
16 years 1 month ago #65955 by drlovecat
Gavick template works on mootools 1.1
So you should contact "the gavick" to fix it "like other" template developers.
16 years 1 month ago #65970 by aaronblrt1
I translated the german page using Google and tried what it said, it did not work using the mystore template.
Also it has been posted on Gavick many times over about Kunena 1.6 and the new mootools and from what I understand, they won't upgrade to the new mootools until Joomla 1.6 comes out because the new mootools wasn't suppose to be put in until then.
