Question How to resize forum!?!
16 years 1 month ago #64788 by sizematters
Hi all, so I just installed the latest Kunena, disabled (removed side modules from forum pages), and set the witdh in the text area of the configuration page.
The forum still remains the same size (450) and I want to increase it to at least 800. My template has a fairly large width so that should not be a problem.
Any ideas?
16 years 1 month ago #64903 by sozzled
Replied by sozzled on topic Re: How to resize forum!?!
G'day, sizematters, and welcome to Kunena.
Have you looked at/changed any Kunena frontend configuration settings? If you're having further problems, please post your K 1.6 configuration report and we'll see what we can to do help.
16 years 1 month ago #65144 by sizematters
Hi sozzled,
I have not changed anything in the frontend.
This is the report as requested:
16 years 1 month ago - 16 years 1 month ago #65164 by sozzled
sizematters wrote: My template has a fairly large width so that should not be a problem.
Your template is entirely responsible for your problem. Your template allows a maximum width of 960px in total width ... for everything ... for your Kunena forum, the left and right modules ... the lot. Now, you've set aside 320px for the left and right modules (combined, including a space between them) which means that you've only got 621px for the width of the forum plus a bit of padding around that. Of that 621px you've got to allow some space for displaying your avatar and a bit more padding, and you're left with a mere 405px to display message content within the forum.
Your site template is the issue and, I'm sorry to say, it's beyond my skill to fix the problem - increase the allowance of space to give you a wider forum - within a few minutes. My advice to you is to contact the template developers ask them if they know how to increase the width of the area allocated to the Joomla component; this really isn't a Kunena problem.
Last edit: 16 years 1 month ago by sozzled.
16 years 1 month ago #65399 by severdia
Replied by severdia on topic Re: How to resize forum!?!
You'll have to change the three main properties that define the structure of your site—the left column, the right column and the container around both those columns. Add the following to the bottom of your main template CSS file:
/* Left Column */ #jv-left-content { width:621px !important; } /* Right Column */ #jv-right { width:320px !important; } /* Outer Container */ .jv-wrapper { width:960px !important; }
Change the widths to match what you want, but unless you get rid of the right column, you can't stick with your current width and make your forum wider. The outer container should be the total of each of the column widths plus 19px.
Time to create page: 0.183 seconds
