Question My buttons are not right...
16 years 2 months ago - 16 years 2 months ago #62812 by fxstein
You css file does not match the buttons.
You can only use a css file based on RC3 AND buttons sets from RC3.
IF you use the css from RC3 but buttons from RC2 - > they will scramble
IF you use the css from RC2 (e.g. you made a copy for a custom template while RC2 was out) but buttons from RC3 -> they will scramble
In some cases the upgrade from RC2 to RC3 will initially look like that until the browser cache is refreshed. If you have done that already, then its one of the above.
So if you are using a custom template, you have to go in there and apply the changes that where made from RC2 to RC3 (link posted before: www.kunena.com/forum/170-k-16-templates-...know-the-diff-to-rc2 ) or you just use the RC3 css file for your new custom template and apply your customizations.
Going forward this is not going to happen again. The css is locked in and frozen for stable. Only in RC2 we had a couple bugs that needed to be cleaned up.
Hope this helps!
Last edit: 16 years 2 months ago by fxstein.
16 years 2 months ago #62853 by jodin
Yep. It was the css files.
