Question Module Position inside message
16 years 2 months ago #62254 by joshblalock
Hi all,
Previous to the update there was a way to set up a module position inside the messages. It was discussed here: www.kunena.com/forum/154-miscellaneous-o...-inside-kunena-forum
Tried the same solution for 1.6 but it did not work. Any way to make this work with 1.6? I figured I'd still need to make changes to message.php
16 years 2 months ago #62338 by fxstein
We should include this inside of Kunena core. Instead of one module position I recommend we do do this like the ones in between message where n is the number of the message. That way you can have a module than only shows inside the first or third or tenth message of a post.
16 years 2 months ago - 16 years 2 months ago #62369 by joshblalock
that would be great! I found a quick fix for any of those who would like to have the module position show up inside of the message rather than below it. edit message.php located here: components/com_kunena/template/default/view
and cut the following code at the very bottom:
<!-- Begin: Message Module Position --> <?php CKunenaTools::showModulePosition('kunena_msg_' . $this->mmm) ?> <!-- Finish: Message Module Position -->
& then paste it either above or below (depending if you want it above or below the message) this near line 121
<?php $this->displayContents() ?>
after that, you can continue to use the positions kunena_msg_# & it should show up inside those messages
hope this helps!
Last edit: 16 years 2 months ago by joshblalock.
